Number Pad Backlight
Brian here, 2 day owner. Tough topic but can’t find an answer. Is the number pad backlit and if it is how do you turn it on?
Seems like according to this:
When you turn the num lock off, Enter key starts toggling the baclight. With + key toggling backlight breathing. Don’t have a num pad myself to confirm, though
Sir, thank you for the quick response and that solved my issue. Do you know where that info is. I looked all over.
You can find a link to it here, plus much more info
frame.work/laptop-16-support
Thank you. Looked right over what I was looking for. Thanks again for your time.
At my age it will take more than a brighter title
