One Key Module Developer Program Recap
Last year, we announced the One Key Module to enable development of custom ultra-low-profile keyboards and Input Modules for Framework Laptop 16. After around three years of design and prototyping along with an extensive Developer Program that we launched earlier this year, we’ve come to the conclusion that unfortunately we won’t be able to turn this into a sellable product. As a general rule, we avoid announcing products before we have full confidence we can ship them. We made an exception in this case to bring in developer feedback during the design process to ensure we were heading in the right direction. What we learned from both our efforts with our supplier and from feedback from developers was extremely valuable and led to our conclusion to halt the product.
First, despite heroic efforts from our engineering and supply chain team members along with their counterparts at our partner Lite-On, we weren’t able to bring material and assembly costs along with manufacturing yield to a place where the product economics worked. The per-key costs resulted in breakeven pricing too high to reasonably enable high volume sales, and neither we nor our suppliers can take on the overhead of manufacturing a product of this complexity at low volumes.
Second, we found that even the expert DIYers and electronics tinkerers who made up our Developer Program cohort had difficulty reliably assembling the One Key Module into their designs. Parts of the module were too fragile for easy handling, further reducing usable yield. There are design tweaks we could make to drive small improvements, but the changes that would truly improve design for assembly would require exceeding the dimensions that fit the constraints of Framework Laptop 16.
We want to thank the developers who participated in the One Key Module Developer Program for both the hard work they put in and for the valuable feedback they provided. There are a number of incredible projects that came of this, and we’ve highlighted each of them below. We had some development modules left, and we’ve been providing these free to the participants in the program to enable them to build additional quantities of their projects if they choose to.
We design our products to be as open as possible to tinkering and extension, and we will continue to enable developers everywhere we can. You can find design files and documentation on our GitHub. If you have a project you’re interested in developing in the Framework ecosystem, check out our Developer Program sign-up form. The next initiative we have coming up is for the Wireless Keyboard Control Board that is part of the Framework Wireless Touchpad Keyboard. Since this is a core module of the product, and one designed from the start for mass production, we avoid the risks that came in for the One Key Module. We’re looking forward to developer feedback, and can’t wait to see the projects that all of you come up with!
HandyWork by Axel Voitier
Handywork is a split ergo keyboard that uses the entire Framework Laptop 16 input deck width. Axel included a lot of resources such as a template PCB to make your own as well as base footprints for both One Key Module and boards fitting the Framework Laptop 16 for A1 form-factors. You can find their progress in our Community Forum as well as their GitHub.
_____________________________________________________________________________________________________________
VBox by Carlo Vaccari
An ergonomic digital-input leverless controller for fighting games, primarily Super Smash Bros. Melee. The VBox is intended to be highly modular and configurable to fit different button layout preferences and hand sizes. You can find more information on their GitHub.
Figleaf Keyboard by Sebastian Graz
Sebastian created Bayleaf, a wireless split ergonomic keyboard built from scratch. Like its predecessor Bayleaf, Figleaf is similarly a wireless, split, low-profile, CNC machined, 60% ortholinear keyboard, but it is built around One Key Module. You can follow their progress on their website.
mikefour by Mike Hölscher
Mike has been building ultra low profile keyboards for the past 2 years including the mikecinq or also known as the mikefive keyboard. The mikefive was named for the 5mm height while the mikefour is for our 4mm height. You can follow their progress on their GitHub.
The Cogito by Paul Staal
The Cogito is a split ergonomic keyboard designed from first principles and actual measurements of a human hand. Rather than improving on the typewriter’s original QWERTY layout, Paul worked through more than fifty 3D-printed prototypes to feature a columnar stagger matched to finger length, a rotated pinky cluster, and a thumb cluster with six keys that support twelve inputs via ZMK hold-tap behaviors. You can follow their work on their website.
Shobo by Aleksandr Krikun
The Shobo is a wireless ZMK split built to be as thin as possible, based around Framework One Key Modules. Aleksandr explores the concept of bringing usually bulky split keyboards into the world of portability, hence the name “Shobo” - a small, concealable spike, perfect to underline the emphasis on portability. You can follow their progress on their website and GitHub.
Framework Missing Keys by Matthew Stephenson
Matthew took a frustration point, the case of PgUp, PgDn, Home, End as missing key options, and set out to add them themself utilizing the spacer area of Framework Laptop 16. You can follow their progress on their webpage and on their GitHub.
Hermes by Enzo Choi
Hermes is an RP2350a based board that uses the entire Framework Laptop 16 input deck width for a split keyboard and center numpad. Minor tweaks to the Lintilla layout were made to fit the available board space. It connects as any other Framework Laptop 16 input module would, but for flashing and limited external use, they’ve included a PCB board edge USB female connector on the top. You can follow their progress on the Community Forum.
As someone who was extremely excited to purchase some of the OKM-derivative products, this is quite sad to hear. May I ask, did you consider substantially increasing the price of the OKM rather than dropping the program entirely? There’s no product like it out there…
I’ll check with the team on this, but I will say, you can apply to the developer program with a project idea if there is something you want to make as we still have some available.
Could you make it significantly cheaper if it weren’t actually just one key?
I’d be willing to pay several hundred extra for something like the Hermes or Shobo, prebuilt as one piece from Framework, on my 13.
Can we actually buy any of the shown keyboards?
The team still found that the pricing would be too high unfortunately. As for if the projects are for sale (@james3 as well), none have stated that, but you can reach out to see if they are interested. You are also welcome to apply to the dev program for the One Key Modules since we have extra left over for the project you’d like to do as the devs have included their process for their projects if you want to try to replicate them.
Hi Framework team,
I’ve been waiting for an integrated ergonomic keyboard like HandyWork for years, so I was really sad to hear that the One Key Modules won’t go into production. Being able to build one is what I’m waiting for before buying a Framework 16.
Could you share what the manufacturing cost would have been for enough OKMs to build one keyboard — for example, the 46 modules used by HandyWork — and what minimum production quantity would be needed?
Could someone in the community take over production, perhaps through a group buy using Lite-On’s existing tooling? Are the published files sufficient, or would additional manufacturing files and permissions be needed?
Thank you for the work you’ve put into this. I’d really love to know whether there’s still a way to make it happen.
Yes, second all of this. Been following these develops actively on these forums since 2023. I understand logistical issues, and it sounds like a real problem since it seems like production is over immediately with what is currently produced is all that’s left.
As mentioned, it would be nice to have some sort of last batch production project. I think those involved and consumers like us deserve the chance to purchase a limited batch production. HandyWork might not be everyone’s ideal layout, but most of us will take something over nothing. We see that since the development is dropped the ROI will not be worth it but I’m sure many of us will potentially pay much more for a batch product. We would all appreciate it if it could be looked into at least just the feasibility.
I understand the outcome but still disappointed. A wireless keyboard from framework is frustrating to hear as basically everyone of us who wanted the custom keyboard layout or at least ortho, have their own custom keyboards and the whole point of following these projects was to have an actual laptop with an integrated non traditional configuration. Avoid having to bring additional peripherals.
(@Thomas_Brooks as well) As stated in the blog, you are welcome to apply to our developer program with your project idea as we do have some One Key Modules left over.
Thanks for your reply!
Glad to hear that there are still OKM left.
I applied to the One Key Module developer program on October 30, but haven’t received a confirmation email or a reply yet.
Could you confirm my application was received?
Yup we’ve received it. I’ll be reviewing these shortly, I was on pto so I’m catching up. Thanks for your patience!
I’ve converted HandyWork to a 42-key Corne for the Framework 16. Huge thanks to Axel for making this possible!
The design files and a preview are in this draft PR:
I have no PCB design experience—all of this work was done with Astra’s help.
Nothing has been built or tested on hardware yet, so I’d really appreciate an experienced pair of eyes before ordering a prototype.
Anyway, once I receive my OKMs and Framework 16, I’ll order a prototype, assemble it and test it.
