Opt out from expedited shipping?
I needed to replace my power adapter’s USB-C. At checkout, I don’t seem to have any choice but to select the expedited shipping, which is close to twice the product’s price (see screenshots)! I love framwork, and I’d rather not go to Amazon or Best Buy, but I’m not paying that much for a USB cable!
Q1 - I’m not in a hurry… Is there a hidden, non-expedited option? Why give us a selection if there’s only one answer?
Q2- If no solution and I have to shop elsewhere, any specs I must look for to insure good performance?
This cable is only USB2.0, you can shop elsewhere a USB 3.0, 3.1, 3.2 or 4, making it dual use (charging & data)
That looks like a store configuration issue possibly. The other possibility is they only offer one form of shipping and its just the expensive one.
The power cable is 240w rated, there are other options, just be sure to get a quality cable from someone like Anker. (Maybe I am thinking this only applies to the larger 180w power adapter?)
@Charlie_6 is right, it is just a basic data cable though.
