Palm Rejection
For Linux libinput “Disable While Typing” (DWT) problems, this page claims libinput will only use the DWT setting if the keyboard and touchpad are either both identified as internal devices, or are both identified as the same device. (The assumption is that if the keyboard and touchpad are separate USB devices, then they won’t be in a fixed position where palm rejection is problem.) If they are identified as different devices, a local device quirk to identify them as internal might help.
Under KDE NEon, while on travel, I have the enabled palm-detection and disable touchpad while typing.
(On my workstation configuration is different reason the pics don’t show it as active). Will be able to tell how it works when I have the FW 16.
Yes! Thank you gcf! That “How to Diagnose Disable-While-Typing Issues” link was just what I needed. The final " What if DWT Doesn’t Work?" section worked. I followed its directions to create a quirks file to set the touchpad and keyboard as “internal” devices the palm clicks seem to be gone completely. Based on a few hours use, it is now as reliable as my old Macbook. This is a considerable improvement in the user experience for this laptop.
:grinning:
Now that it has been a few days, I can confirm quirks fix from linuxtouchpad.org does fix the problem for my FW13-AMD.
I have noticed that while typing, the cursor does sometimes move from the palm, but it does not tap! I’m not the original poster, but I would mark this as [SOLVED] for me.
I’m on Windows and my only solution has been to turn off tap to click, a feature I use regularly, but I can’t use the touchpad otherwise.
Can you share what the quirks file looks like?
I had been meaning to update this thread. Nothing had fixed the problem and I gave up on it. I disabled tap to click a month or two ago. I use the laptop while on my couch and realized my posture (and how that affected my hands’ position) was the main variable after all.
In any case, the quirks file is below, but I don’t think it helped.
/etc/libinput/local-overrides.quirks
[Serial Keyboards]
MatchUdevType=keyboard
MatchName=AT Translated Set 2 keyboard
AttrKeyboardIntegration=internal
[Touchpad]
MatchUdevType=touchpad
MatchName=PIXA3854:00 093A:0274 Touchpad
Just spent some time pinning down a disable-while-typing issue. My problem turned out to be the keyd virtual keyboard. Most people report success from adding an AttrKeyboardIntegration=internal quirk (per linuxtouchpad.org link previously shared in this thread) but that was not the case for me. Querying libinput quirks list for the device confirmed that the quirks file had taken effect, but DWT issues persisted.
With keyd disabled, DWT is working as expected on my system. I assume I’d face the same issue with any other remap tool that surfaces as a libinput virtual device, but I haven’t actually tried. I’m able to replace keyd with xkb_options for my needs, so I’ll leave keyd disabled for now.
FWIW, I’m running Arch on an AMD FW13 with keyd@2.4.3-6, libinput@1.25.0-1, linux-lts@6.6.30-2, sway@1:1.9-3.
Sorry, I’ve kind of “lost the thread” on this thread over the months as I struggle with this problem. I’m running Fedora 39 Silverblue/Bluefin/GNOME/Wayland. Before I go digging too deep on doing this with my weird distro, do you think this would be X-only (I’m guessing by “xkb,”) or are you using Wayland as well?
Yep, I’m using Sway, which is a Wayland compositor. (This is new territory for me, so take this with a dash of salt, but as I understand it Wayland still uses XKB formatting and libs for keymapping.)
I think the quickest way to test if our situations match is to run sudo libinput list-devices (you may need to install libinput-tools first) and see if keyd virtual device or keyd virtual keyboard is listed. If you see such a device in the listing then you probably installed keyd at some point for custom keyboard mapping.
If you’re using systemd then sudo systemctl stop keyd is a quick way to stop keyd temporarily. After that, try opening a text editor and see if palm rejection behaves any better. If it makes no difference then you can run sudo systemctl start keyd again and no harm done. It makes a big difference for me, so I used sudo systemctl disable keyd to keep keyd disabled permanently for now (but I’m leaving its installation and configs in place because I’m hoping there’s a fix out there rather than relying on xkb options as a limited workaround.)
Thanks. I’ve been using Fedora/Bluefin because of its awesome Framework-specific ISO, but there is no checkbox for DWT in the GNOME settings.
I just tried:
gsettings set org.gnome.desktop.peripherals.touchpad disable-while-typing true
and I think it’s helping so far. But sometimes it takes a day or two for me to determine if a change has been helpful or not.
Running sudo libinput list-devices doesn’t show anything with “keyd” or “virtual” so I think that’s a variation in our distros. But a part of the libinput list-devices output says Disable-w-typing: enabled. So I’m hoping that’s what I need.
If that gsettings fix is what I need, I will bring it up in the Bluefin forums; see if there’s a reason it isn’t in GNOME settings. I’ve been joyfully distro-hopping since I got this thing in November but this one issue isn’t well handled by any of them so far.
I think I have narrowed down the problem some!
In Mac, when I start typing, the mouse pointer disappears as a sign that the touchpad is inactive while typing. Through all my experiments with different distros on the Framework, I don’t remember noticing the cursor ever disappearing.
When I entered the above “gsettings” command, I noticed the pointer disappearing like the Mac. Cool! Progress! In the last week, things are markedly better but I would still have palm clicks from time to time. Today. I was typing a long email in Chrome and the palm clicks were driving me crazy. And the pointer wasn’t disappearing.
From my testing:
The pointer does not disappear: Chrome, KeepassXC, Calibre, Pinta
The pointer disappears (and presumably disables while typing: Files, Double Commander, Text Editor, Software, Gedit, GIMP, Konsole, Ptyxis, Firefox
So it’s looking to me less like an unfixable hardware problem, but rather a bug at the application or toolkit level. Included GNOME apps work, and but does Konsole, so it doesn’t seem be a GTK/QT split. Going by the aesthetics of the nonworking apps, I’d guess it’s an issue of them using older versions of the toolkits.
I’ve been meaning to try migrating from Chrome to Firefox for awhile. I think this will make me do it.
FWIW, adding this quirks file has solved the accidental-tap problem for me (in conjunction with the DWT setting in the Gnome settings under “Touchpad”) on a Framework 13 with Ubuntu 24.10. Thank you for posting it!
Have been having the same issues for a while in Windows 11, have just been resorting to disabling the touchpad and connecting an external mouse:
Does anyone have any ideas on how to resolve this issue on Windows 11?
I did find one potential workaround in Windows 11, which is to reduce the touchpad sensitivity. I had it on “Most sensitive” when I got the issues, now am experimenting with medium to high sensitivity to see if that solves the issues for me. See below screenshot:
Fighting the phantom click / palm rejection / disable while typing. I’m using a FW13 on Ubuntu 24.04.2. Frustrating since I’ve tried a lot of solutions that seem to have worked for other people on the same machine.
According to libinput quirks list /dev/event2 my keyboard is internal. According to gsettings get org.gnome.desktop.peripherals.touchpad disable-while-typing, my setting is on.
Interestingly, I ran libinput debug-events for a little while and while of course I can’t get the issue to happen on demand, I’m not seeing any mouse events when the cursor repositions (and highlights all the text in-between ). See attached screenshots, one of the debug-events log (with --show-keycodes and one of my Joplin window after I CTRL-Zed back to have all the text highlighted that had gotten deleted while I was typing.
Maybe I’m triggering some accessibility mode or something? Something else is firing the click?
I love this laptop but I’ve struggled with this problem since I bought it. I’m at the point where I need to be able to type without constantly watching to see if I’m deleting the last 3 minutes of writing.
Appreciate any suggestions! Thank you!
Sorry to reply to my own call for help, but a little further information.
I booted the laptop from a Linux Mint live image to see if it had the same issue and, even with the disable while typing flag set in the OS it behaves the same as my Ubuntu installation.
I suppose I’ll stop chasing this and just table tap to click. Frustrating, but better than the current experience.
I still use tap to click. But i have the touchpad “Disabled when a mouse is attached.” When I switch on my Bluetooth mouse I can effectively type without problems. I don’t pull out the mouse if I’m just casually watching Youtube or reading. This solution is depressingly not ideal but it’s the best I can do.
Playing with the pressure or size never quite worked reliably. I’ve found better results with changing the palm edge size. This is not a tunable in the local override. I’ve put together a patch in case it is helpful to anyone.
diff --git a/src/evdev-mt-touchpad.c b/src/evdev-mt-touchpad.c
index 1ddfe409..448c1f5a 100644
--- a/src/evdev-mt-touchpad.c
+++ b/src/evdev-mt-touchpad.c
@@ -3296,17 +3296,17 @@ tp_init_palmdetect_edge(struct tp_dispatch *tp, struct evdev_device *device)
                return;
        /* palm edges are 8% of the width on each side */
-       mm.x = min(8, width * 0.08);
+       mm.x = min(8, width * 0.11);
        edges = evdev_device_mm_to_units(device, &mm);
        tp->palm.left_edge = edges.x;
-       mm.x = width - min(8, width * 0.08);
+       mm.x = width - min(8, width * 0.11);
        tp->palm.right_edge = edges.x;
        if (!tp->buttons.has_topbuttons && height > 55) {
                /* top edge is 5% of the height */
-               mm.y = height * 0.05;
+               mm.y = height * 0.40;
                tp->palm.upper_edge = edges.y;
This seems to be a known issue, with a known workaround recommendation, in the keyd project. It sounds like you’ve resolved your issue by moving off of keyd but in case someone else comes across this with a similar issue, here is a good description of putting the workaround in place and testing it out.
