Hey Everyone,
I have a mild issue with my laptop’s wifi.
I have a TP link AX3000 router with AX 160mhz turned on. I have a desktop computer using an Intel AX200 and my older Thinkpad A485 (AMD version of a T480) using an Intel AC9260. Both of these computers and cards can reach around 600-800mbps from a room a short distance away from the router but my Framework Laptop is only pulling around 200 mbps down in a speed test.
If I go next to the router I can get 900mbps with the Framework and AX210 no problem. I have the latest drivers from Intel on Windows 11 and triple checked my antenna wires to the card. Even put a piece of electrical tape on the metal clamp to prevent the antenna wires from interfering with eachother.
Tried a couple other things things. Installed the AC9260 from the Thinkpad with the same results. Also tried a live Ubuntu 21.10 environment with also the same results. So to me this rules out my card and Windows. Issue might the antennas or the PCIe link on the mainboard if I were to guess.
Anyone else seeing something similar?
