Qualcomm WCN785x Wi-Fi 7 / Bluetooth Installed. Bluetooth will pair but not connect
Which Linux distro are you using? Mint
Which release version? 22.1 Xia, Cinnamon 6.4.8
Which kernel are you using? 6.8.0-64-generic
Which BIOS version are you using? 6.8.0-64-generic
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
May need a later kernel than 6.8. Also worth waiting until Mint 22.2 available and retest.
Definitely try a more recent kernel. That one is quite old and there have been a lot of Wi-Fi improvements in the kernel these past few months.
I’ve never had to upgrade to a newer kernel before. How do I go about it? Also, why would Mint use an older kernel on a new install if there are newer ones available?
Stability. One of the benefits of Mint. You want the latest there are other distros for that.
Sorry I don’t run Mint. It is based off Debian/Ubuntu and sticks to the same kernel version they do. You should be able to find some kernel upgrade guides online for any of those distros that will work for Mint. I would recommend just going to the mainline rc kernel which is reported stable and looks to be about to go out of rc status.
Depending on your knowledge of Linux, you may just want to wait for the next release to come out.
I will tell you though, I installed this same card in my fw16 a while back and there were a few kernel versions that contained a bluetooth bug regarding key verification. I forget the details off-hand, but it prevented me from using headsets or game controllers. They simply would not connect. Besides that, even older kernels didn’t even support things like headsets on this card. I think when I first installed it the only thing I could get working on bluetooth was my keyboard.
This card is relatively new and took a few patches in the kernel (linux drivers are largely in the kernel) to get it working right. This card really didn’t get stable til around kernel 6.15.3 I think.
Take a browse through this thread. I linked to where it kinda started working stable for me, but earlier up you can read about the bluetooth issues.
