My wifi disconnects continuously, while the macbook I keep next to my framework doesn’t have this problem.
I have the AMD 13th generation, running Linux Mint, and I have run the network tester, but I am not sure I understand the result
Eventually try a more recent kernel as it has more recent drivers.
The network tester will not help you if the issue is on the WiFi card itself.
Are you tied to Linux Mint as a daily driver? If not, I highly recommend looking into trying Bluefin on your Framework, as various fixes have been applied by the Universal Blue team mentioned here.
If tied to Linux Mint, have you run through a full system update recently?
I am happy with Linux Mint, and I have run a full system update. I might give a try to Bluefin, but Linux Mint is very close to Ubuntu so it should work correctly, I am running 6.8.0-49 as a kernel
Hmm, may I ask the result of checking what your network card is with the following command?
lspci | grep Network
If your result is something like the Intel AX210 card or newer, I tend to recommend being on 6.10+ kernels as I’ve seen better stability on it on those newer kernels, but others in the community may also have better recommendations here.
