Qualityproblems with the 61Wh battery
This is my second battery swollen up.
So every battery lived for about 1 year.
Is this a wider known issue or am I the bad-luck guy?
Try limiting the battery charge to 80% all the time. This will dramatically increase the chance the battery will not be damaged.
Statistically yes it is possible to have two poorly manufacturerd batteries. Though it is likely the state of charge at or near 100% and/or temperature changes that is causing the demise.
Hi @erkan_yanar Have you opened a ticket with support?
I did, still waiting for a response :slight_smile:
Temperature is a god point.
As mentioned in another post. Despite claiming framework being fully supported by Ubuntu,
you need to scan this forum to find fw-fwcrtl. So having a dysfunctional could have led to my batteryproblems.
