I need a replacement for the screw that holds down the wifi card, I found this guide which says it’s “an M2 3.0mm fastener with a T5 head which is 4.5mm in diameter and 0.7mm thick” - but I’m unable to find something that matches this on Amazon.
In the first image, marked with pink markers, we have the gold colored fastener that is used for WiFi, Storage, and the Audio Board. This is an M2 3.0mm fastener with a T5 head which is 4.5mm in diameter and 0.7mm thick.
It’s typically a few days from Framework but next-day from Amazon - but it’s ok, I can use the spare on the mainboard for now and buy a replacement from Framework.
most of the ones labelled m.2 or nvme mounting screw will do, just check to make sure you see M2 3mm, and be careful trying to screw it in, since if it isn’t exactly correct it could strip it.
