(Request) Framework 16 boot error LED blink codes
It was nice to see at least one help page which mentioned the LED blink codes for Framework 13 here: My Framework Laptop (Intel 11th Gen Intel® Core™) is not powering on . But I couldn’t find anything for Framework 16.
I am sure a lot of customers would appreciate similar information for Framework 16 as well. If anyone already knows some of the boot up LED blink codes, please share them here.
What would be really awesome if someone comes up with a way to translate the blink codes and send output to the LED Matrix Input Module! Not sure if it’s even possible but an idea!
The effort vs benefit ratio for that will not be worth it IMO, if it even is possible (the LED matrix most likely requires a driver and communication with a running OS). If there is a table for those codes, like it is common even for mainstream brands like Dell, it makes it very easy to quickly see the most likely cause. For example, if it’s a missing/disconnected RAM or a faulty one etc.
