[RESPONDED] Won't boot! LED blinks out code 4, 9, 10
  • OS: Ubuntu Linux
  • Which generation: I have no idea. I bought it in February 2022.
Hey all! I purchased my Framework DIY less than 2 years ago and recently while online shopping, it suddenly powered off and became a vegetable.
When I try to power it on, the light around the power button responds, then turns off, and the led light on the charging port blinks out a code with green and red lights. By reading this article, I have been able to understand what the code means, but not how to act on it:
The following failed:
  • 4: CPU deassert sleep s4
  • 9: Fan detected and spins up
  • 10: CPU reached S0 state
I followed the guide to fully reset the mainboard, but it made no difference. The same thing happened when I tried to power on the laptop again.
I may need a replacement battery, but I have heard nothing from Framework support since filing my issue at the end of November-- just the automated acknowledgement.
Does anybody have any advice I can take in the meantime while I try to keep hope alive that Framework will reach out to me?
Hi @Ned_Redmond, welcome to the community!
I noted your ticket that you have reached out. With the current support load, and the weekend, this doesn’t look to be missed. I have verified your ticket is open and will be attended to as our small team works through the queue. Appreciate your patience.
I suspect you may indeed, need a replacement battery. Best advice, do not reply to the ticket (slows things down). We have it and will be getting to it asap. Again, appreciate your patience with this.
Having same issue and have reached out. What was the resolution?
