[RESOLVED] Unable to Connect to ESP32
I can connect to it with Thonny on my old laptop running Ubuntu but not on my Framework (also running Ubuntu)… Anyone have any ideas?
Syslog:
Jul 11 17:11:33 framework kernel: [ 1902.876026] usb 3-3: new full-speed USB device number 15 using xhci_hcd
Jul 11 17:11:34 framework kernel: [ 1903.125115] usb 3-3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
Jul 11 17:11:34 framework kernel: [ 1903.125124] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 11 17:11:34 framework kernel: [ 1903.125127] usb 3-3: Product: CP2102 USB to UART Bridge Controller
Jul 11 17:11:34 framework kernel: [ 1903.125129] usb 3-3: Manufacturer: Silicon Labs
Jul 11 17:11:34 framework kernel: [ 1903.125132] usb 3-3: SerialNumber: 0001
Jul 11 17:11:34 framework kernel: [ 1903.134504] cp210x 3-3:1.0: cp210x converter detected
Jul 11 17:11:34 framework kernel: [ 1903.135460] usb 3-3: cp210x converter now attached to ttyUSB0
Jul 11 17:11:34 framework mtp-probe: checking bus 3, device 15: “/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3”
Jul 11 17:11:34 framework mtp-probe: bus: 3, device: 15 was not an MTP device
Jul 11 17:11:34 framework snapd[862]: udevmon.go:149: udev event error: Unable to parse uevent, err: cannot parse libudev event: invalid env data
Jul 11 17:11:34 framework snapd[862]: hotplug.go:199: hotplug device add event ignored, enable experimental.hotplug
Jul 11 17:11:35 framework brltty[524]: USB configuration set error 16: Device or resource busy
Jul 11 17:11:35 framework brltty[524]: brltty: USB configuration set error 16: Device or resource busy
Jul 11 17:11:35 framework brltty[524]: brltty: USB interface in use: 0 (cp210x)
Jul 11 17:11:35 framework brltty[524]: USB interface in use: 0 (cp210x)
Jul 11 17:11:35 framework kernel: [ 1904.762120] usb 3-3: usbfs: interface 0 claimed by cp210x while ‘brltty’ sets config #1
Jul 11 17:11:35 framework kernel: [ 1904.762845] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
Jul 11 17:11:35 framework kernel: [ 1904.762878] cp210x 3-3:1.0: device disconnected
Jul 11 17:11:35 framework ModemManager[1015]: [base-manager] port ttyUSB0 released by device ‘/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3’
Jul 11 17:11:35 framework ModemManager[1015]: [base-manager] couldn’t check support for device ‘/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3’: Operation was cancelled
Seems like it may just be a difference of Ubuntu versions rather than the laptop doing anything.
Here’s a thread from the Arduino forums with a quite similar-looking report where the “brltty” package is interfering with the serial connection. Note that your logs also mention “brltty,” which seems to be installed by default on current Ubuntu versions.
Removing brltty worked. Thanks!
just to summarize, that’s what I did to disable the brltty service:
systemctl stop brltty-udev.service
sudo systemctl mask brltty-udev.service
systemctl stop brltty.service
systemctl disable brltty.service
I’m not sure if this could have any side effect on oany other system context but after this and restarting the arduino ide I got a new port entry which is ttyUSB0, and the non working old one ttyS4 is still listed.
Delighted this has been resolved. I assume this was for BRLTTY, correct?
In my case I’m still investigating some issues, slowly due to lack of time at the moment.
After stopping the brltty service I saw the usb connected to my esp-32 and the arduino ide saw it too, but after a while it disappeared.
Probably this has to do in my case because of the battery extension guide->usb-autosuspend. So probably I need to whitelist my esp-32 (and each one of them I work with) or I need to disable that part of the saving-battery policy.
Once I try this out I will come back and confirm!
Yep, this would be the next step. :slight_smile:
