Issue is as described in the title. I’ve been using my Framework laptop with two USB A cards, an HDMI card, and a USB C card for some time now. I recently decided that I need another USB A port more than I need the HDMI, so I ordered another card and plugged it in. Everything seemed fine at first, but when I tried to plug something into the third USB A port, all of my USB devices disconnected. Now none of my USB A ports work.
I’ve tried all three expansion cards in every slot and none of them seem to work with any of the devices I’ve tried to plug in (which all work on other machines). The USB C card still seems to work fine in all slots, suggesting it’s just an issue with the USB A cards. I have three of them, and two were working just fine before, so I doubt it’s an issue with faulty expansion cards. Tried rebooting, as well as checking for firmware updates with fwupdmgr – no dice.
$ sudo dmesg | tail
[ 1505.646711] usb 3-9: reset full-speed USB device number 3 using xhci_hcd
[ 1851.719163] lockdown_is_locked_down: 5 callbacks suppressed
[ 1851.719166] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[ 2147.702286] usb 3-9: reset full-speed USB device number 3 using xhci_hcd
[ 2664.526482] usb usb2-port1: attempt power cycle
[ 2672.982449] usb usb2-port1: unable to enumerate USB device
OS: Fedora 38
CPU: 11th Gen Intel(R) Core™ i5-1135G7 @ 2.40GHz
BIOS: 03.17
Kernel: 6.4.15-200.fc38.x86_64
