[RESOLVED] VMWare on Ryzen with Ubuntu 22.04
I am using a Ryzen 22.04 with the default kernel on an AMD machine.
Linux framework 6.1.0-1026-oem #26-Ubuntu SMP PREEMPT_DYNAMIC Wed Nov  1 14:06:23 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
I followed the instructions given here:
https://volvodiag.com/ubuntu-vmware-kernel-module-install-guide/
I did:
mkdir repos
cd repos
git clone https://github.com/mkubecek/vmware-host-modules
cd vmware-host-modules/
git checkout workstation-17.5.0
cd vmmon-only && make && cd ..
cd vmnet-only && make && cd ..
tar -cf vmmon.tar vmmon-only
tar -cf vmnet.tar vmnet-only
sudo cp -v vmmon.tar vmnet.tar /usr/lib/vmware/modules/source/
sudo apt install libaio1
sudo vmware-modconfig --console --install-all
This fails with the message:
ufechner@framework:~$ sudo vmware-modconfig --console --install-all
[sudo] password for ufechner:
[AppLoader] GLib does not have GSettings support.
Stopping VMware services:
   VMware Authentication Daemon                                        done
   Virtual machine monitor                                             done
make: Entering directory '/tmp/modconfig-VPKEfw/vmmon-only'
Using kernel build system.
/usr/bin/make -C /lib/modules/6.1.0-1026-oem/build/include/.. M=$PWD SRCROOT=$PWD/. \
  MODULEBUILDDIR= modules
make[1]: Entering directory '/usr/src/linux-headers-6.1.0-1026-oem'
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
  You are using:           gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/linux/driver.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/linux/driverLog.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/linux/hostif.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/apic.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/comport.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/cpuid.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/crosspage.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/memtrack.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/moduleloop.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/phystrack.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/sharedAreaVmmon.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/statVarsVmmon.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/task.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/common/vmx86.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/bootstrap/bootstrap.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/bootstrap/monLoader.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/bootstrap/monLoaderVmmon.o
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/bootstrap/vmmblob.o
  LD [M]  /tmp/modconfig-VPKEfw/vmmon-only/vmmon.o
  MODPOST /tmp/modconfig-VPKEfw/vmmon-only/Module.symvers
  CC [M]  /tmp/modconfig-VPKEfw/vmmon-only/vmmon.mod.o
  LD [M]  /tmp/modconfig-VPKEfw/vmmon-only/vmmon.ko
  BTF [M] /tmp/modconfig-VPKEfw/vmmon-only/vmmon.ko
Skipping BTF generation for /tmp/modconfig-VPKEfw/vmmon-only/vmmon.ko due to unavailability of vmlinux
make[1]: Leaving directory '/usr/src/linux-headers-6.1.0-1026-oem'
/usr/bin/make -C $PWD SRCROOT=$PWD/. \
  MODULEBUILDDIR= postbuild
make[1]: Entering directory '/tmp/modconfig-VPKEfw/vmmon-only'
make[1]: 'postbuild' is up to date.
make[1]: Leaving directory '/tmp/modconfig-VPKEfw/vmmon-only'
cp -f vmmon.ko ./../vmmon.o
make: Leaving directory '/tmp/modconfig-VPKEfw/vmmon-only'
make: Entering directory '/tmp/modconfig-VPKEfw/vmnet-only'
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/driver.o
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/hub.o
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/userif.o
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/netif.o
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/bridge.o
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/procfs.o
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/smac_compat.o
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/smac.o
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/vnetEvent.o
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/vnetUserListener.o
  LD [M]  /tmp/modconfig-VPKEfw/vmnet-only/vmnet.o
  MODPOST /tmp/modconfig-VPKEfw/vmnet-only/Module.symvers
  CC [M]  /tmp/modconfig-VPKEfw/vmnet-only/vmnet.mod.o
  LD [M]  /tmp/modconfig-VPKEfw/vmnet-only/vmnet.ko
  BTF [M] /tmp/modconfig-VPKEfw/vmnet-only/vmnet.ko
Skipping BTF generation for /tmp/modconfig-VPKEfw/vmnet-only/vmnet.ko due to unavailability of vmlinux
make[1]: Entering directory '/tmp/modconfig-VPKEfw/vmnet-only'
make[1]: Leaving directory '/tmp/modconfig-VPKEfw/vmnet-only'
cp -f vmnet.ko ./../vmnet.o
make: Leaving directory '/tmp/modconfig-VPKEfw/vmnet-only'
Starting VMware services:
   Virtual machine monitor                                            failed
   Virtual machine communication interface                             done
   VM communication interface socket family                            done
   Virtual ethernet                                                   failed
Any idea how to make it work? Do I need to use another kernel?
Linux kernel 6.1 is from January, it probably won’t have stable support for 7840 yet. I would vote for upgrade to a more recent kernel, maybe 6.5+.
P.S. Oh, it should run with the OEM C kernel. Dunno then.
Yep seeing in other threads that kernel 6.5x with Ubuntu 22.04 seems to work mostly for them with some minor issues though.
Only when you can, please update to a more recent supported distro, like Fedora 39 and Ubuntu 23.04
cheers! :slight_smile:
This is resolved. The issue was that I had secure boot enabled.
Thanks for the update @Uwe_Fechner :slight_smile:
