I get the error when I try pressing the powerbutton to suspend the laptop. Nothing happens afterward. I’m running Ubuntu 20.04.
Hi @Jamie_Lahowetz welcome to the community
May we ask what Framework laptop you’re currently using? and can we try if same symptoms
is showning when you boot ubuntu 22.04.3?
its a Framework 13 and I’m running Ubuntu 20.04
You will need to run 22.04.03, to be sure it has the right kernels that is known to work with framework.
cheers!
