Hello Friends, I’m a new Framework owner, and for whatever reason, the power button no longer shows the shutdown menu when pressed. I’ve gone into power settings and everything seems to be in order. How can I troubleshoot this problem?
Hi @Jason_Ju ,
Welcome to the community ![]()
Let’s check if issue is config based, distro based or Hardware
Try running Linux Mint live and Ubuntu 22.04.3 Live and see if power button issue is persistent.
cheers! ![]()
I think I bypassed the issue. Instead of setting config files, I just went to keyboard shortcuts and set suspend to power button. Works perfectly now.
Interesting workaround ![]()
