[RESPONDED] Framework and PopOS
I’m also using Pop!_OS. When the power button is pulsing (suspend, in my setup) and I wake my machine, I need to press the power button to bring things back online. When the machine is hibernated, the power button is off, and needs to be pressed to bring things back online. Resumption in either case returns to the state when the machine was suspended - applications and windows all are restored. What do you have the system set to do in the /etc/systemd/sleep.conf and /etc/systemd/logind.conf files? I have mine configured to suspend then hibernate. It looks like your system is trying to hibernate but failing to do so - I could be wrong, however.
Interesting. For me, when opening the lid back up, the power button does not pulse. The sleep.conf and logind.conf files are what came default with Pop_OS!:
// sleep.conf
[Sleep]
#AllowSuspend=yes
#AllowHibernation=yes
#AllowSuspendThenHibernate=yes
#AllowHybridSleep=yes
#SuspendMode=
#SuspendState=mem standby freeze
#HibernateMode=platform shutdown
#HibernateState=disk
#HybridSleepMode=suspend platform shutdown
#HybridSleepState=disk
#HibernateDelaySec=180min
// logind.conf
[Login]
#NAutoVTs=6
#ReserveVT=6
#KillUserProcesses=no
#KillOnlyUsers=
#KillExcludeUsers=root
#InhibitDelayMaxSec=5
#UserStopDelaySec=10
#HandlePowerKey=poweroff
#HandleSuspendKey=suspend
#HandleHibernateKey=hibernate
#HandleLidSwitch=suspend
#HandleLidSwitchExternalPower=suspend
#HandleLidSwitchDocked=ignore
#HandleRebootKey=reboot
#PowerKeyIgnoreInhibited=no
#SuspendKeyIgnoreInhibited=no
#HibernateKeyIgnoreInhibited=no
#LidSwitchIgnoreInhibited=yes
#RebootKeyIgnoreInhibited=no
#HoldoffTimeoutSec=30s
#IdleAction=ignore
#IdleActionSec=30min
#RuntimeDirectorySize=10%
#RuntimeDirectoryInodes=400k
#RemoveIPC=yes
#InhibitorsMax=8192
#SessionsMax=8192
I’m going to try doing echo mem > /sys/power/state and report back to see if the system can even go into a deep sleep (aka. suspend-to-RAM) state.
If you’re using something like Gnome or KDE, you have to configure power stuff using their settings (they override systemd defaults).
After doing some more digging, it looks like I’m running into the issue here: Unable to wake from sleep
Putting it to sleep using echo mem > /sys/power/state, the power button starts to pulse but I cannot bring it out of sleep. Pressing the power button again makes the LED turn on fully, then off after a second. If I press it again, it looks like it just reboots.
I currently have scaling set to 150% and the tearing is getting annoying. When searching for solutions I found 2 common ways that people have fixed this:
Install xf86-video-intel which I can’t figure out how to do.
Or enable Wayland, but that doesn’t seem to be enabling:
Restarted and it’s still X11:
Here’s my display settings:
Has anyone been able to resolve the tearing at 150% in Pop 21.10?
Did you choose the right gnome session (with wayland) on GDM ?
Changing this config enables this option, but you still need to select it from login screen
Ah, there we go, selected Pop on Wayland from the little gear after clicking on my username and I’m all set now, thanks @fdr !
OK new question, with Wayland, the trackpad has a lot of inertia when scrolling, is there any way to disable this? It would make sense with a touchscreen, but I always end up scrolling past when I wants to stop.
I at least found a way to disable the inertia/kinetic scrolling in Firefox, but it’d be nice to disable it system-wide.
I’m getting much better performance from Wayland, it seems to have fixed the issue of media playback above 1080p on an external monitor being super laggy and CPU heavy.
Fractional scaling seems better in terms of apps scaling properly, albeit blurry. I’d like to disable fractional scaling on a per app basis but I havent found a way yet, unfortunately this means apps like Discord are blurry.
I found a related bug for this with VS Code being blurry and it turns out to be related to electron, and should be fixed in an upcoming release.
Ah interesting, thats good to know. Thanks
I can second this, display performance is better on Wayland - not noticing any blurriness with apps. I typically keep video playback at 480/720p since I mostly view videos at 2x+. I had previously found scaling to 200% and then minimizing in app display to 80% to be helpful
Also didn’t need the screen tearing fix on Wayland
@Alex5 probably it’s a bit late to answer, but I had the same problems with touchpad after wake up and disabling PS/2 emulation (or I don’t know how exactly it’s called there) helped. Haven’t had any problems since then
@Alex5 I have the same issue with the trackpad. After using a MacBook trackpad, I’m extremely disappointed with this one.
Think there are a few things that Apple is industry-leading:
  1. Laptop speakers
  2. Trackpad
  3. Processor performance per W
  4. Display scaling and graphical user experience
  5. Built-in headphone jack capable for high impedance headphone (waiting for reviews).
i.e. I’m saying, it’s pretty much a known standard that if you’re not on a Macbook…the trackpad would automatically fall into the ‘can’t compare to Apple’ category.
Trackpad disappointment is near-guaranteed for any Macbook users using anything else.
PC laptops just don’t have that full control over hardware, OS, apps, sales, distribution, trade-in…etc. Be it good or bad.
Question about OS update. I use PopOS 21 on my Framework for about half a year already, so far so mostly good :slight_smile: Recently it started showing me the pop up that update to 22 is available. So the question is how bad is the idea of doing such ‘live major update’ 21 → 22?
Previously, I used macOS as my work OS for about 10+ years and such major updates work mostly fine there. Yet, I had a really bad experience updating the Linux the same ~10 years back. Some of my previous old Ubuntus basically crashed after a minor upgrade with apt-get.
Many people upgraded with no issues. I did so on a couple of machines, but on my primary had a fair amount of hassle. I believe that I have it ok now, but in the mean time swapped the ssd and am now running manjaro. If you haven’t added any third party ppas you likely will be fine. Just make sure to have a backup in case things do go sideways.
@ololobus FWIW I’ve upgraded mine with only very minor issues, all of which have been resolved.
@ololobus I had pretty major issues that resulted in booting from a USB to repair the system. Fortunately I had a backup with Timeshift and my data was partitioned. Id definitely recommend a backup prior to the update.
