Restore backup FW13 Ryzen 7840
Hi Framework community.
This is my first FW laptop so please bear with me.
FW13 - AMD Ryzen 7840 - Windows 11
I just completed the install of Windows following the directions and got the new driver’s installed but because I bypassed the Microsoft account setup at install (as per the instructions, in order to get the correct driver’s installed) I’m not able to restore the backup from my last laptop (I was running an Intel based laptop but I wouldn’t think that should matter).
So, I’m coming here to ask if there is any easy way to restore my backup without doing a Windows reinstall. And if not, if I do a reinstall of Windows, won’t I run into the same issue with the drivers?
Thanks for take y’all’s assistance.
We need more information.
What was on the old PC that you want to get back?
What goes wrong when you try to restore?
What software did you use to make the backup?
