Suspend is working properly if I have no external monitors connected.
However, if I have a monitor connected to displayport, the first time I suspend and resume, everything is fine. But on the second suspend/resume, while resuming it appears that something (hyprland?) crashes and I am logged into a fresh session.
I am running NixOS 24.05, kernel 6.6.31 and hyprland. I have the latest DP and HDMI modules.
Have you tried a supported OS, via a live USB ?
No I haven’t. I guess that might tell me if my hardware is having problems. I am just wondering if anyone else is having similar problems. Maybe they tried a “supported OS” and can shed some light. Maybe they found a workaround for some oddity of the framework modules.
FWIW I’ve tried HDMI with Ubuntu 24.04 and its’ fine
Hi,
I have the same issue: Ubuntu 24.04.3, upgrade from Ubuntu 22.04 with an External Monitor connected via DP, if I suspend without first locking the screen, the Notebook will log me out.
Will also try with HDMI.
Thanks a lot
