From EG95 hardware design document page 39:
PWRKEY can be pulled down directly to GND with a recommended 10 kΩ resistor if module needs to be powered on automatically and shutdown is not needed.
Also for next iteration of board design, you can consider breaking out as much test points for useful pins as you can fit on the board. From your image there seems to be a lot of space unused behind the main antenna connector.
