Can anyone confirm for me if the mainboard uses a 12V 4 pin RGB header, or a 5V 3 pin ARGB header?
I’m looking to purchase the MB for a custom build, and I’m finding conflicting info about the header. To clarify, I’m not asking about the PWM header, but the single RGB/ARGB header.
In addition, what are our options for adjusting the fan curves for case fans? Is it all through the BIOS?
