FW Desktop ARGB header issue?
So I installed an ARGB 80mm front fan, and 3 LEDs out of 11 didn’t work. I thought I was just unlucky and ordered a new one, and the new one arrived and acts the same way, both daisy-chained or directly connected to the ARGB header.
I’m thinking I cannot be that unlucky, so I try both fans in my old PC, and both work fine with all LEDs working.
I also took out some LED strips from my old PC to see if they work in the FW Desktop, and they don’t work properly. Both strips have a total of 18 LEDs, from which only the first 8 light up when connected to the FW. Both of them act the same way.
My CPU fan, Cooler Master Mobius 120p ARGB, works just fine.
Any ideas what’s going on? Or did I miss something?
Later edit: solved the issue, just had to follow the advanced part at this post, which I completely missed initially Framework Desktop ARGB Driver for Windows - BETA
