Ryzen HX 370 TDP
I’m checking out the CPUs in the new Ryzen lineup. It is fantastic that the HX 370 is even offered in a 13" laptop, and if it is able to perform that’s probably what I’ll go for.
What is the maximum TDP of the HX 370 as set by Framework?
Is the FW13 able to maintain the 5.1 GHz boost clock (does the new single-heatpipe design have enough cooling capacity to handle this beast)?
Is there anyone that actually has the 350 or HX 370 mainboard that would be willing to share their experience?
yes, it should be 35w max sustained boost. It hasn’t started shipping yet iirc
you should be able to increase it (at your own risk) with smokeless UMAF to about 45w max sustained boost which is about the max that the FW13 cooling system can handle with maxed out fans
