RZ 717 wifi 7
Salut tous,
Je pose une question qui va intéresser du monde je pense :
Est ce que le module wifi 7 AMD RZ717 qui a été annoncé hier sera compatible avec les Laptop 16 ryden 7 et 9 ???
Merci pour les reponses…
Ludovic.
Someone mentioned that the older wifi cards were compatible with the new framework 13 so I assume the new wifi card is also compatible with the previous generation.
ca sera bien… mais pour l’instant Framework | AMD RZ717 Wi-Fi 7 il est pas indiqué comme compatible. P’etre qu’ils attendent de valider avant? :crossed_fingers:
Not listed as compatible with other than Ryzen300 for now…
First, translation (per Google Translate):
The RZ717 is also known as the MediaTek MT7925, which you can find on Amazon, eBay, etc. I have these installed in a Framework 16 7940HS, and various Framework 13’s including 7840U, 7640U, 1370P, 1280P, 1260P, and an 1135G7. I think I also installed the same in my DeepComputing RISC-V board but I’m not entirely certain; I may have had to swap that out for an AX210 due to the older kernel but I’m not sure.
Edit: I remember about the RISC-V board now; I never actually tried the RZ717, I only tried the AX210 and had firmware loading issues. Will report back when/if I try the RZ717 as I have a handful of extras.
See some previous discussion in Wifi 7 clarification and more threads linked therein.
The RZ717 and RZ738 (with MediaTek MT7925 and MT7927, respectively) have both been installed and work in Framework 16 laptops.
But everyone seems quite underwhelmed by them. Driver issues, same speeds as RZ616, and still doesn’t seem to have proper full support for Bluetooth LE Audio.
