Screen Freezing / Stuttering
  • OS: Microsoft Windows 11 Pro
  • Version: 10.0.26100 Build 26100
  • Framework Laptop: Framework Laptop 16 (AMD Ryzen™ 7040 Series)
I’m having an issue where my screen seems to stuttering / freezing every now & then.
If I have a second display connected that works fine with no issue.
Everything still works as it would. As I type this my screen freezes on words, but I can still type & when the screen refreshes itself all my “missing” text appears.
I did do a reinstallation of my OS just in case & still noticed the issue.
It could be a heat related issue, but I’m not sure exactly sure. It gets hot when charging but if I unplug from the charger it’s in battery saver & efficiency mode so it shouldn’t be that.
