Screen goes black but audio stays on. Framework 13 less than a year old
PLEASE READ BEFORE POSTING:
Are you looking into the forum because you’re having potential issues with your Framework product? Before creating a post, we may have a guide, FAQ, or thread that can hopefully help!
In the body of your post, please include those following details.
  • Which OS (Operating System)?
  • Which release of your OS (Operating System / Windows 10, 11)? (if you are having a Linux related issue, please create your thread under the Linux subcategory)
  • Which Framework product (Laptop 13, Laptop 16, Laptop 12 or Desktop) and which generation of CPU (Intel 11th gen, Intel 12th gen , Intel 13th gen, Intel Ultra Series 1, Chromebook, AMD 7040 Series, AMD AI 300 Series, AMD AI Max 300 Series) or GPU (NVIDIA® GeForce RTX™ 5070, AMD Radeon™ RX 7700S)
  • If there is no information pertaining to your issue or question, please let us know here: Framework | Support https://frame.work/support
I bought my DIY framework 13 computer November 2024. Here are my computer’s details. Framework Laptop 13 DIY Edition (Intel® Core™ Ultra Series 1) System: Ultra 7 155H Memory: DDR5-5600 - 32GB (2 x 16GB) Storage: WD_BLACK™ SN850X NVMe™- M.2 2280 - 4TB Laptop Bezel: Framework Laptop 13 Bezel – Black Operating System: Windows 11 Home Edition
About a week ago, my screen started going black while I was using it. Sometimes only an hour after using it. Other times a couple of hours. I’ve noticed that when I’m watching Netflix or other media, the screen goes black but the audio stays on. In fact, it appears that the show is still going on in the background. I try to move my finger across the touchpad / trackpad but it doesn’t do any good. I also try pushing the space bar. Since I can’t see the screen, I do a hard shutdown (holding down the power button for 10 seconds.) When I reboot, the computer seems to work, but sometimes does it again an hour or two later. Again, the audio always works and whatever is in the background appears to be playing.
I’m not sure if this is an update issue or a hardware issue.
@Rita_Jeffries If you haven’t already, please reach out to our support.
Thanks Eagle! I’ll do that!
