Hi all,
My Batch 6 laptop arrived yesterday. I got the Intel AX210 wifi card.
I am trying to install Linux Mint 20.2 MATE edition, but ran into some hardware issues.
A. With the default kernel (2.4), the touchpad and Wifi do not work. It is expected that the WiFi would not work, since it became part of the kernel starting at 2.10. However, when I upgrade the kernel, WiFi works but…
B. The screen resolution at 2256x1504 3:2 stops working - the option is there at a much lower refresh rate, but the actual resolution I see is not 2256x1504. Everything is much larger.
I do not know what is causing this issue…Is there a way to have all 3 (Touchpad, Resolution, WiFi) work at the same time?
Thank you!
