[SOLVED] Brightness keys only work on reboot
Since a few weeks I’ve been having issues with the brightness keys, and only the brightness keys. When the issue is happening, the brightness - and + don’t react. The other media keys such as play, pause, mute, volume - and + work fine.
It’s similar to the issues described in this thread: [SOLVED] 13th Gen Intel Framework 13 running Fedora 38, media keys aren't working
Currently I have kernel 6.3.12-200. I’m using Fedora 38 with the 12th gen Intel. While it was happening, I checked if the module was blacklisted properly. I checked my / proc / cmdline to check if it did boot with the module blacklisted:
cat / proc / cmdline
BOOT_IMAGE=(hd0,gpt2)/vmlinuz-6.3.12-200.fc38.x86_64 root=UUID=00000000-0000-0000-0000-000000000000 ro rootflags=subvol=root rd.luks.uuid=luks-00000000-0000-0000-0000-000000000000 rhgb quiet nvme.noacpi=1 module_blacklist=hid_sensor_hub
Showkey doesn’t show anything for the FN brightness - and + keys when it happens.
The strange thing is, this only seems to happen on a cold boot. When I reboot using the reboot command then the keys work again. If I then proceed to shutdown completely shutdown -h now and then press the power button to boot up again, the media keys don’t work.
Could anybody help be debug this issue?
Showkey shows nothing at all, as if no key was even pressed? I’m not certain, but it seemed as if Showkey registers keypresses at a low level. Even for keys that aren’t configured, you still get a scan code.
~edit~
evtest was what I was thinking of, rather than showkey.
How about evtest, does it register?
sudo apt install evtest
sudo evtest
Then press 2, then try pressing the keys
No reaction at all, here is an overview of when I pressed fn-F1 up until fn-F12. You can see that after KEY_NEXTSONG it goes straight to KEY_P.
evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:	Lid Switch
/dev/input/event1:	Power Button
/dev/input/event10:	HDA Intel PCH HDMI/DP,pcm=3
/dev/input/event11:	HDA Intel PCH HDMI/DP,pcm=7
/dev/input/event12:	HDA Intel PCH HDMI/DP,pcm=8
/dev/input/event13:	HDA Intel PCH HDMI/DP,pcm=9
/dev/input/event2:	AT Translated Set 2 keyboard
/dev/input/event3:	ImExPS/2 Generic Explorer Mouse
/dev/input/event4:	PIXA3854:00 093A:0274 Mouse
/dev/input/event5:	PIXA3854:00 093A:0274 Touchpad
/dev/input/event6:	Video Bus
/dev/input/event7:	PC Speaker
/dev/input/event8:	HDA Intel PCH Mic
/dev/input/event9:	HDA Intel PCH Headphone
Select the device event number [0-13]: 2
Input driver version is 1.0.1
Input device ID: bus 0x11 vendor 0x1 product 0x1 version 0xab83
Input device name: "AT Translated Set 2 keyboard"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 1 (KEY_ESC)
    Event code 2 (KEY_1)
    Event code 3 (KEY_2)
    Event code 4 (KEY_3)
    Event code 5 (KEY_4)
    Event code 6 (KEY_5)
    Event code 7 (KEY_6)
    Event code 8 (KEY_7)
    Event code 9 (KEY_8)
    Event code 10 (KEY_9)
    Event code 11 (KEY_0)
    Event code 12 (KEY_MINUS)
    Event code 13 (KEY_EQUAL)
    Event code 14 (KEY_BACKSPACE)
    Event code 15 (KEY_TAB)
    Event code 16 (KEY_Q)
    Event code 17 (KEY_W)
    Event code 18 (KEY_E)
    Event code 19 (KEY_R)
    Event code 20 (KEY_T)
    Event code 21 (KEY_Y)
    Event code 22 (KEY_U)
    Event code 23 (KEY_I)
    Event code 24 (KEY_O)
    Event code 25 (KEY_P)
    Event code 26 (KEY_LEFTBRACE)
    Event code 27 (KEY_RIGHTBRACE)
    Event code 28 (KEY_ENTER)
    Event code 29 (KEY_LEFTCTRL)
    Event code 30 (KEY_A)
    Event code 31 (KEY_S)
    Event code 32 (KEY_D)
    Event code 33 (KEY_F)
    Event code 34 (KEY_G)
    Event code 35 (KEY_H)
    Event code 36 (KEY_J)
    Event code 37 (KEY_K)
    Event code 38 (KEY_L)
    Event code 39 (KEY_SEMICOLON)
    Event code 40 (KEY_APOSTROPHE)
    Event code 41 (KEY_GRAVE)
    Event code 42 (KEY_LEFTSHIFT)
    Event code 43 (KEY_BACKSLASH)
    Event code 44 (KEY_Z)
    Event code 45 (KEY_X)
    Event code 46 (KEY_C)
    Event code 47 (KEY_V)
    Event code 48 (KEY_B)
    Event code 49 (KEY_N)
    Event code 50 (KEY_M)
    Event code 51 (KEY_COMMA)
    Event code 52 (KEY_DOT)
    Event code 53 (KEY_SLASH)
    Event code 54 (KEY_RIGHTSHIFT)
    Event code 55 (KEY_KPASTERISK)
    Event code 56 (KEY_LEFTALT)
    Event code 57 (KEY_SPACE)
    Event code 58 (KEY_CAPSLOCK)
    Event code 59 (KEY_F1)
    Event code 60 (KEY_F2)
    Event code 61 (KEY_F3)
    Event code 62 (KEY_F4)
    Event code 63 (KEY_F5)
    Event code 64 (KEY_F6)
    Event code 65 (KEY_F7)
    Event code 66 (KEY_F8)
    Event code 67 (KEY_F9)
    Event code 68 (KEY_F10)
    Event code 69 (KEY_NUMLOCK)
    Event code 70 (KEY_SCROLLLOCK)
    Event code 71 (KEY_KP7)
    Event code 72 (KEY_KP8)
    Event code 73 (KEY_KP9)
    Event code 74 (KEY_KPMINUS)
    Event code 75 (KEY_KP4)
    Event code 76 (KEY_KP5)
    Event code 77 (KEY_KP6)
    Event code 78 (KEY_KPPLUS)
    Event code 79 (KEY_KP1)
    Event code 80 (KEY_KP2)
    Event code 81 (KEY_KP3)
    Event code 82 (KEY_KP0)
    Event code 83 (KEY_KPDOT)
    Event code 85 (KEY_ZENKAKUHANKAKU)
    Event code 86 (KEY_102ND)
    Event code 87 (KEY_F11)
    Event code 88 (KEY_F12)
    Event code 89 (KEY_RO)
    Event code 90 (KEY_KATAKANA)
    Event code 91 (KEY_HIRAGANA)
    Event code 92 (KEY_HENKAN)
    Event code 93 (KEY_KATAKANAHIRAGANA)
    Event code 94 (KEY_MUHENKAN)
    Event code 95 (KEY_KPJPCOMMA)
    Event code 96 (KEY_KPENTER)
    Event code 97 (KEY_RIGHTCTRL)
    Event code 98 (KEY_KPSLASH)
    Event code 99 (KEY_SYSRQ)
    Event code 100 (KEY_RIGHTALT)
    Event code 102 (KEY_HOME)
    Event code 103 (KEY_UP)
    Event code 104 (KEY_PAGEUP)
    Event code 105 (KEY_LEFT)
    Event code 106 (KEY_RIGHT)
    Event code 107 (KEY_END)
    Event code 108 (KEY_DOWN)
    Event code 109 (KEY_PAGEDOWN)
    Event code 110 (KEY_INSERT)
    Event code 111 (KEY_DELETE)
    Event code 112 (KEY_MACRO)
    Event code 113 (KEY_MUTE)
    Event code 114 (KEY_VOLUMEDOWN)
    Event code 115 (KEY_VOLUMEUP)
    Event code 116 (KEY_POWER)
    Event code 117 (KEY_KPEQUAL)
    Event code 118 (KEY_KPPLUSMINUS)
    Event code 119 (KEY_PAUSE)
    Event code 121 (KEY_KPCOMMA)
    Event code 122 (KEY_HANGUEL)
    Event code 123 (KEY_HANJA)
    Event code 124 (KEY_YEN)
    Event code 125 (KEY_LEFTMETA)
    Event code 126 (KEY_RIGHTMETA)
    Event code 127 (KEY_COMPOSE)
    Event code 128 (KEY_STOP)
    Event code 140 (KEY_CALC)
    Event code 142 (KEY_SLEEP)
    Event code 143 (KEY_WAKEUP)
    Event code 155 (KEY_MAIL)
    Event code 156 (KEY_BOOKMARKS)
    Event code 157 (KEY_COMPUTER)
    Event code 158 (KEY_BACK)
    Event code 159 (KEY_FORWARD)
    Event code 163 (KEY_NEXTSONG)
    Event code 164 (KEY_PLAYPAUSE)
    Event code 165 (KEY_PREVIOUSSONG)
    Event code 166 (KEY_STOPCD)
    Event code 172 (KEY_HOMEPAGE)
    Event code 173 (KEY_REFRESH)
    Event code 183 (KEY_F13)
    Event code 184 (KEY_F14)
    Event code 185 (KEY_F15)
    Event code 217 (KEY_SEARCH)
    Event code 226 (KEY_MEDIA)
  Event type 4 (EV_MSC)
    Event code 4 (MSC_SCAN)
  Event type 17 (EV_LED)
    Event code 0 (LED_NUML) state 0
    Event code 1 (LED_CAPSL) state 0
    Event code 2 (LED_SCROLLL) state 0
Key repeat handling:
  Repeat type 20 (EV_REP)
    Repeat code 0 (REP_DELAY)
      Value    250
    Repeat code 1 (REP_PERIOD)
      Value     33
Properties:
Testing ... (interrupt to exit)
Event: time 1690015357.044745, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1690015357.044745, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1690015357.044745, -------------- SYN_REPORT ------------
Event: time 1690015359.221768, type 4 (EV_MSC), code 4 (MSC_SCAN), value a0
Event: time 1690015359.221768, type 1 (EV_KEY), code 113 (KEY_MUTE), value 1
Event: time 1690015359.221768, -------------- SYN_REPORT ------------
Event: time 1690015359.335075, type 4 (EV_MSC), code 4 (MSC_SCAN), value a0
Event: time 1690015359.335075, type 1 (EV_KEY), code 113 (KEY_MUTE), value 0
Event: time 1690015359.335075, -------------- SYN_REPORT ------------
Event: time 1690015360.095685, type 4 (EV_MSC), code 4 (MSC_SCAN), value ae
Event: time 1690015360.095685, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 1
Event: time 1690015360.095685, -------------- SYN_REPORT ------------
Event: time 1690015360.231367, type 4 (EV_MSC), code 4 (MSC_SCAN), value ae
Event: time 1690015360.231367, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 0
Event: time 1690015360.231367, -------------- SYN_REPORT ------------
Event: time 1690015360.902259, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1690015360.902259, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1
Event: time 1690015360.902259, -------------- SYN_REPORT ------------
Event: time 1690015361.034653, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1690015361.034653, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0
Event: time 1690015361.034653, -------------- SYN_REPORT ------------
Event: time 1690015361.758513, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90
Event: time 1690015361.758513, type 1 (EV_KEY), code 165 (KEY_PREVIOUSSONG), value 1
Event: time 1690015361.758513, -------------- SYN_REPORT ------------
Event: time 1690015361.878539, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90
Event: time 1690015361.878539, type 1 (EV_KEY), code 165 (KEY_PREVIOUSSONG), value 0
Event: time 1690015361.878539, -------------- SYN_REPORT ------------
Event: time 1690015362.724964, type 4 (EV_MSC), code 4 (MSC_SCAN), value a2
Event: time 1690015362.724964, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 1
Event: time 1690015362.724964, -------------- SYN_REPORT ------------
Event: time 1690015362.842471, type 4 (EV_MSC), code 4 (MSC_SCAN), value a2
Event: time 1690015362.842471, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 0
Event: time 1690015362.842471, -------------- SYN_REPORT ------------
Event: time 1690015363.580738, type 4 (EV_MSC), code 4 (MSC_SCAN), value 99
Event: time 1690015363.580738, type 1 (EV_KEY), code 163 (KEY_NEXTSONG), value 1
Event: time 1690015363.580738, -------------- SYN_REPORT ------------
Event: time 1690015363.716240, type 4 (EV_MSC), code 4 (MSC_SCAN), value 99
Event: time 1690015363.716240, type 1 (EV_KEY), code 163 (KEY_NEXTSONG), value 0
Event: time 1690015363.716240, -------------- SYN_REPORT ------------
Event: time 1690015366.991724, type 4 (EV_MSC), code 4 (MSC_SCAN), value db
Event: time 1690015366.991724, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 1
Event: time 1690015366.991724, -------------- SYN_REPORT ------------
Event: time 1690015366.992139, type 4 (EV_MSC), code 4 (MSC_SCAN), value 19
Event: time 1690015366.992139, type 1 (EV_KEY), code 25 (KEY_P), value 1
Event: time 1690015366.992139, -------------- SYN_REPORT ------------
Event: time 1690015367.132898, type 4 (EV_MSC), code 4 (MSC_SCAN), value 19
Event: time 1690015367.132898, type 1 (EV_KEY), code 25 (KEY_P), value 0
Event: time 1690015367.132898, -------------- SYN_REPORT ------------
Event: time 1690015367.133551, type 4 (EV_MSC), code 4 (MSC_SCAN), value db
Event: time 1690015367.133551, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 0
Event: time 1690015367.133551, -------------- SYN_REPORT ------------
Event: time 1690015369.361766, type 4 (EV_MSC), code 4 (MSC_SCAN), value b7
Event: time 1690015369.361766, type 1 (EV_KEY), code 99 (KEY_SYSRQ), value 1
Event: time 1690015369.361766, -------------- SYN_REPORT ------------
Event: time 1690015369.475383, type 4 (EV_MSC), code 4 (MSC_SCAN), value b7
Event: time 1690015369.475383, type 1 (EV_KEY), code 99 (KEY_SYSRQ), value 0
Event: time 1690015369.475383, -------------- SYN_REPORT ------------
Event: time 1690015370.894740, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690015370.894740, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 1
Event: time 1690015370.894740, -------------- SYN_REPORT ------------
Event: time 1690015371.045533, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690015371.045533, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 0
Event: time 1690015371.045533, -------------- SYN_REPORT ------------
Event: time 1690015371.906770, type 4 (EV_MSC), code 4 (MSC_SCAN), value 01
Event: time 1690015371.906770, type 1 (EV_KEY), code 1 (KEY_ESC), value 1
Event: time 1690015371.906770, -------------- SYN_REPORT ------------
Event: time 1690015372.026620, type 4 (EV_MSC), code 4 (MSC_SCAN), value 01
Event: time 1690015372.026620, type 1 (EV_KEY), code 1 (KEY_ESC), value 0
Event: time 1690015372.026620, -------------- SYN_REPORT ------------
Event: time 1690015375.229970, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690015375.229970, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 1
Event: time 1690015375.229970, -------------- SYN_REPORT ------------
Event: time 1690015375.368526, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690015375.368526, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 0
Event: time 1690015375.368526, -------------- SYN_REPORT ------------
Event: time 1690015378.878905, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690015378.878905, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1690015378.878905, -------------- SYN_REPORT ------------
Event: time 1690015379.014557, type 4 (EV_MSC), code 4 (MSC_SCAN), value 2e
Event: time 1690015379.014557, type 1 (EV_KEY), code 46 (KEY_C), value 1
Event: time 1690015379.014557, -------------- SYN_REPORT ------------
^C
Or run again and do only evtest, fn-bright- and fn-bright+ and then ctrl-c:
Event: time 1690015539.040933, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1690015539.040933, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1690015539.040933, -------------- SYN_REPORT ------------
Event: time 1690015546.031282, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690015546.031282, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1690015546.031282, -------------- SYN_REPORT ------------
Event: time 1690015546.225646, type 4 (EV_MSC), code 4 (MSC_SCAN), value 2e
Event: time 1690015546.225646, type 1 (EV_KEY), code 46 (KEY_C), value 1
Event: time 1690015546.225646, -------------- SYN_REPORT ------------
^C
Let me reboot and report the different output then.
Edit after reboot. Now the brightness keys work and this is the output:
evtest
Available devices:
/dev/input/event10:	PC Speaker
/dev/input/event11:	HDA Intel PCH Mic
/dev/input/event12:	HDA Intel PCH Headphone
/dev/input/event13:	HDA Intel PCH HDMI/DP,pcm=3
/dev/input/event14:	HDA Intel PCH HDMI/DP,pcm=7
/dev/input/event15:	HDA Intel PCH HDMI/DP,pcm=8
/dev/input/event16:	HDA Intel PCH HDMI/DP,pcm=9
/dev/input/event4:	FRMW0001:00 32AC:0006 Wireless Radio Control
/dev/input/event5:	FRMW0001:00 32AC:0006 Consumer Control
/dev/input/event6:	FRMW0001:00 32AC:0006
/dev/input/event7:	PIXA3854:00 093A:0274 Mouse
/dev/input/event8:	PIXA3854:00 093A:0274 Touchpad
/dev/input/event9:	Video Bus
Select the device event number [0-16]: 2
Supported events:
      Value    250
      Value     33
Properties:
Event: time 1690016023.250696, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1690016023.250696, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1690016023.250696, -------------- SYN_REPORT ------------
Event: time 1690016025.538116, type 4 (EV_MSC), code 4 (MSC_SCAN), value a0
Event: time 1690016025.538116, type 1 (EV_KEY), code 113 (KEY_MUTE), value 1
Event: time 1690016025.538116, -------------- SYN_REPORT ------------
Event: time 1690016025.673151, type 4 (EV_MSC), code 4 (MSC_SCAN), value a0
Event: time 1690016025.673151, type 1 (EV_KEY), code 113 (KEY_MUTE), value 0
Event: time 1690016025.673151, -------------- SYN_REPORT ------------
Event: time 1690016026.156885, type 4 (EV_MSC), code 4 (MSC_SCAN), value ae
Event: time 1690016026.156885, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 1
Event: time 1690016026.156885, -------------- SYN_REPORT ------------
Event: time 1690016026.295096, type 4 (EV_MSC), code 4 (MSC_SCAN), value ae
Event: time 1690016026.295096, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 0
Event: time 1690016026.295096, -------------- SYN_REPORT ------------
Event: time 1690016026.637231, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1690016026.637231, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1
Event: time 1690016026.637231, -------------- SYN_REPORT ------------
Event: time 1690016026.766249, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1690016026.766249, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0
Event: time 1690016026.766249, -------------- SYN_REPORT ------------
Event: time 1690016027.160491, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90
Event: time 1690016027.160491, type 1 (EV_KEY), code 165 (KEY_PREVIOUSSONG), value 1
Event: time 1690016027.160491, -------------- SYN_REPORT ------------
Event: time 1690016027.268077, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90
Event: time 1690016027.268077, type 1 (EV_KEY), code 165 (KEY_PREVIOUSSONG), value 0
Event: time 1690016027.268077, -------------- SYN_REPORT ------------
Event: time 1690016027.692928, type 4 (EV_MSC), code 4 (MSC_SCAN), value a2
Event: time 1690016027.692928, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 1
Event: time 1690016027.692928, -------------- SYN_REPORT ------------
Event: time 1690016027.806936, type 4 (EV_MSC), code 4 (MSC_SCAN), value a2
Event: time 1690016027.806936, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 0
Event: time 1690016027.806936, -------------- SYN_REPORT ------------
Event: time 1690016028.189071, type 4 (EV_MSC), code 4 (MSC_SCAN), value 99
Event: time 1690016028.189071, type 1 (EV_KEY), code 163 (KEY_NEXTSONG), value 1
Event: time 1690016028.189071, -------------- SYN_REPORT ------------
Event: time 1690016028.318106, type 4 (EV_MSC), code 4 (MSC_SCAN), value 99
Event: time 1690016028.318106, type 1 (EV_KEY), code 163 (KEY_NEXTSONG), value 0
Event: time 1690016028.318106, -------------- SYN_REPORT ------------
Event: time 1690016030.178095, type 4 (EV_MSC), code 4 (MSC_SCAN), value db
Event: time 1690016030.178095, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 1
Event: time 1690016030.178095, -------------- SYN_REPORT ------------
Event: time 1690016030.180279, type 4 (EV_MSC), code 4 (MSC_SCAN), value 19
Event: time 1690016030.180279, type 1 (EV_KEY), code 25 (KEY_P), value 1
Event: time 1690016030.180279, -------------- SYN_REPORT ------------
Event: time 1690016030.285359, type 4 (EV_MSC), code 4 (MSC_SCAN), value 19
Event: time 1690016030.285359, type 1 (EV_KEY), code 25 (KEY_P), value 0
Event: time 1690016030.285359, -------------- SYN_REPORT ------------
Event: time 1690016030.286113, type 4 (EV_MSC), code 4 (MSC_SCAN), value db
Event: time 1690016030.286113, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 0
Event: time 1690016030.286113, -------------- SYN_REPORT ------------
Event: time 1690016031.350493, type 4 (EV_MSC), code 4 (MSC_SCAN), value b7
Event: time 1690016031.350493, type 1 (EV_KEY), code 99 (KEY_SYSRQ), value 1
Event: time 1690016031.350493, -------------- SYN_REPORT ------------
Event: time 1690016031.482813, type 4 (EV_MSC), code 4 (MSC_SCAN), value b7
Event: time 1690016031.482813, type 1 (EV_KEY), code 99 (KEY_SYSRQ), value 0
Event: time 1690016031.482813, -------------- SYN_REPORT ------------
Event: time 1690016033.121436, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690016033.121436, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 1
Event: time 1690016033.121436, -------------- SYN_REPORT ------------
Event: time 1690016033.272064, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690016033.272064, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 0
Event: time 1690016033.272064, -------------- SYN_REPORT ------------
Event: time 1690016034.211963, type 4 (EV_MSC), code 4 (MSC_SCAN), value 01
Event: time 1690016034.211963, type 1 (EV_KEY), code 1 (KEY_ESC), value 1
Event: time 1690016034.211963, -------------- SYN_REPORT ------------
Event: time 1690016034.313098, type 4 (EV_MSC), code 4 (MSC_SCAN), value 01
Event: time 1690016034.313098, type 1 (EV_KEY), code 1 (KEY_ESC), value 0
Event: time 1690016034.313098, -------------- SYN_REPORT ------------
Event: time 1690016035.021993, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690016035.021993, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 1
Event: time 1690016035.021993, -------------- SYN_REPORT ------------
Event: time 1690016035.163328, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690016035.163328, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 0
Event: time 1690016035.163328, -------------- SYN_REPORT ------------
Event: time 1690016038.884695, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690016038.884695, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1690016038.884695, -------------- SYN_REPORT ------------
Event: time 1690016039.134953, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690016039.134953, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1690016039.134953, -------------- SYN_REPORT ------------
Event: time 1690016039.169022, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690016039.169022, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1690016039.169022, -------------- SYN_REPORT ------------
Event: time 1690016039.202084, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690016039.202084, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1690016039.202084, -------------- SYN_REPORT ------------
Event: time 1690016039.235996, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690016039.235996, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1690016039.235996, -------------- SYN_REPORT ------------
Event: time 1690016039.269629, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690016039.269629, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1690016039.269629, -------------- SYN_REPORT ------------
Event: time 1690016039.303695, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690016039.303695, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1690016039.303695, -------------- SYN_REPORT ------------
Event: time 1690016039.306732, type 4 (EV_MSC), code 4 (MSC_SCAN), value 2e
Event: time 1690016039.306732, type 1 (EV_KEY), code 46 (KEY_C), value 1
Event: time 1690016039.306732, -------------- SYN_REPORT ------------
^C
And again with only the brightness keys:
Event: time 1690016159.810043, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1690016159.810043, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1690016159.810043, -------------- SYN_REPORT ------------
Event: time 1690016165.245386, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690016165.245386, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1690016165.245386, -------------- SYN_REPORT ------------
Event: time 1690016165.468570, type 4 (EV_MSC), code 4 (MSC_SCAN), value 2e
Event: time 1690016165.468570, type 1 (EV_KEY), code 46 (KEY_C), value 1
Event: time 1690016165.468570, -------------- SYN_REPORT ------------
^C
It looks like the brightness keys still don’t show up, but they work now. Let’s just check showkey again, and it shows:
showkey
kb mode was ?UNKNOWN?
[ if you are trying this under X, it might not work
since the X server is also reading /dev/console ]
press any key (program terminates 10s after last keypress)...
keycode  28 release
keycode 224 press
keycode 224 release
keycode 225 press
keycode 225 release
keycode  29 press
^Ccaught signal 2, cleaning up...
That’s odd, have you tried with live distro and retest with evtest?
Same thing, brightness keys don’t work from a fresh Fedora 38 live image:
Event: time 1690229393.859752, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1690229393.859752, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1690229393.859752, -------------- SYN_REPORT ------------
Event: time 1690229397.315625, type 4 (EV_MSC), code 4 (MSC_SCAN), value a0
Event: time 1690229397.315625, type 1 (EV_KEY), code 113 (KEY_MUTE), value 1
Event: time 1690229397.315625, -------------- SYN_REPORT ------------
Event: time 1690229397.432575, type 4 (EV_MSC), code 4 (MSC_SCAN), value a0
Event: time 1690229397.432575, type 1 (EV_KEY), code 113 (KEY_MUTE), value 0
Event: time 1690229397.432575, -------------- SYN_REPORT ------------
Event: time 1690229397.940516, type 4 (EV_MSC), code 4 (MSC_SCAN), value ae
Event: time 1690229397.940516, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 1
Event: time 1690229397.940516, -------------- SYN_REPORT ------------
Event: time 1690229398.054286, type 4 (EV_MSC), code 4 (MSC_SCAN), value ae
Event: time 1690229398.054286, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 0
Event: time 1690229398.054286, -------------- SYN_REPORT ------------
Event: time 1690229398.556001, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1690229398.556001, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1
Event: time 1690229398.556001, -------------- SYN_REPORT ------------
Event: time 1690229398.697942, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1690229398.697942, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0
Event: time 1690229398.697942, -------------- SYN_REPORT ------------
Event: time 1690229399.156567, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90
Event: time 1690229399.156567, type 1 (EV_KEY), code 165 (KEY_PREVIOUSSONG), value 1
Event: time 1690229399.156567, -------------- SYN_REPORT ------------
Event: time 1690229399.286525, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90
Event: time 1690229399.286525, type 1 (EV_KEY), code 165 (KEY_PREVIOUSSONG), value 0
Event: time 1690229399.286525, -------------- SYN_REPORT ------------
Event: time 1690229399.800108, type 4 (EV_MSC), code 4 (MSC_SCAN), value a2
Event: time 1690229399.800108, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 1
Event: time 1690229399.800108, -------------- SYN_REPORT ------------
Event: time 1690229399.941431, type 4 (EV_MSC), code 4 (MSC_SCAN), value a2
Event: time 1690229399.941431, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 0
Event: time 1690229399.941431, -------------- SYN_REPORT ------------
Event: time 1690229400.419044, type 4 (EV_MSC), code 4 (MSC_SCAN), value 99
Event: time 1690229400.419044, type 1 (EV_KEY), code 163 (KEY_NEXTSONG), value 1
Event: time 1690229400.419044, -------------- SYN_REPORT ------------
Event: time 1690229400.551436, type 4 (EV_MSC), code 4 (MSC_SCAN), value 99
Event: time 1690229400.551436, type 1 (EV_KEY), code 163 (KEY_NEXTSONG), value 0
Event: time 1690229400.551436, -------------- SYN_REPORT ------------
Event: time 1690229402.746722, type 4 (EV_MSC), code 4 (MSC_SCAN), value db
Event: time 1690229402.746722, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 1
Event: time 1690229402.746722, -------------- SYN_REPORT ------------
Event: time 1690229402.747104, type 4 (EV_MSC), code 4 (MSC_SCAN), value 19
Event: time 1690229402.747104, type 1 (EV_KEY), code 25 (KEY_P), value 1
Event: time 1690229402.747104, -------------- SYN_REPORT ------------
Event: time 1690229402.897365, type 4 (EV_MSC), code 4 (MSC_SCAN), value 19
Event: time 1690229402.897365, type 1 (EV_KEY), code 25 (KEY_P), value 0
Event: time 1690229402.897365, -------------- SYN_REPORT ------------
Event: time 1690229402.897876, type 4 (EV_MSC), code 4 (MSC_SCAN), value db
Event: time 1690229402.897876, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 0
Event: time 1690229402.897876, -------------- SYN_REPORT ------------
Event: time 1690229404.227538, type 4 (EV_MSC), code 4 (MSC_SCAN), value b7
Event: time 1690229404.227538, type 1 (EV_KEY), code 99 (KEY_SYSRQ), value 1
Event: time 1690229404.227538, -------------- SYN_REPORT ------------
Event: time 1690229404.365971, type 4 (EV_MSC), code 4 (MSC_SCAN), value b7
Event: time 1690229404.365971, type 1 (EV_KEY), code 99 (KEY_SYSRQ), value 0
Event: time 1690229404.365971, -------------- SYN_REPORT ------------
Event: time 1690229405.533653, type 4 (EV_MSC), code 4 (MSC_SCAN), value 01
Event: time 1690229405.533653, type 1 (EV_KEY), code 1 (KEY_ESC), value 1
Event: time 1690229405.533653, -------------- SYN_REPORT ------------
Event: time 1690229405.635075, type 4 (EV_MSC), code 4 (MSC_SCAN), value 01
Event: time 1690229405.635075, type 1 (EV_KEY), code 1 (KEY_ESC), value 0
Event: time 1690229405.635075, -------------- SYN_REPORT ------------
Event: time 1690229406.426939, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690229406.426939, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 1
Event: time 1690229406.426939, -------------- SYN_REPORT ------------
Event: time 1690229406.543604, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1690229406.543604, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 0
Event: time 1690229406.543604, -------------- SYN_REPORT ------------
Event: time 1690229409.265087, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690229409.265087, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1690229409.265087, -------------- SYN_REPORT ------------
Event: time 1690229409.496225, type 4 (EV_MSC), code 4 (MSC_SCAN), value 2e
Event: time 1690229409.496225, type 1 (EV_KEY), code 46 (KEY_C), value 1
Event: time 1690229409.496225, -------------- SYN_REPORT ------------
^C
Only brightness keys:
Event: time 1690229595.361423, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1690229595.361423, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1690229595.361423, -------------- SYN_REPORT ------------
Event: time 1690229597.631235, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690229597.631235, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1690229597.631235, -------------- SYN_REPORT ------------
Event: time 1690229597.828263, type 4 (EV_MSC), code 4 (MSC_SCAN), value 2e
Event: time 1690229597.828263, type 1 (EV_KEY), code 46 (KEY_C), value 1
Event: time 1690229597.828263, -------------- SYN_REPORT ------------
^C
On this one: Linux localhost-live 6.2.9-300.fc38.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Mar 30 22:32:58 UTC 2023 x86_64 GNU/Linux
Going to try rebooting into the live image (doing reboot and immediately pressing F12 to boot straight into the flash drive again) to see if they’ll work then. Edit in 2-3 minutes.
Edit:
That still didn’t work! No brightness keys.
I realized I’ve been testing with the live media wrong. I can properly reproduce it with the live image now. I forgot to append the module blacklist to the boot parameters. So what I did now:
  1. Press F12 to get into boot mode
  2. Select flash drive with live image of Fedora 38
  3. Press E in grub, append module_blacklist=hid_sensor_hub to kernel options, F10 to boot
  4. Brightness keys don’t work
  5. Send reboot command
  6. Press F12 to get into boot mode
  7. Select flash drive with live image of Fedora 38
  8. Press E in grub, append module_blacklist=hid_sensor_hub to kernel options, F10 to boot
  9. Brightness keys do work
Evkeys (only brightness, then CTRL-C) of step 9):
Event: time 1690230569.894867, type 4 (EV_MSC), code 4 (MSC_SCAN), value 03
Event: time 1690230569.894867, type 1 (EV_KEY), code 3 (KEY_2), value 0
Event: time 1690230569.894867, -------------- SYN_REPORT ------------
Event: time 1690230569.968699, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1690230569.968699, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1690230569.968699, -------------- SYN_REPORT ------------
Event: time 1690230574.487163, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1690230574.487163, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1690230574.487163, -------------- SYN_REPORT ------------
Event: time 1690230574.668663, type 4 (EV_MSC), code 4 (MSC_SCAN), value 2e
Event: time 1690230574.668663, type 1 (EV_KEY), code 46 (KEY_C), value 1
Event: time 1690230574.668663, -------------- SYN_REPORT ------------
^C
So in conclusion, this issue persists over the live image.
I Wonder if behavior persist on Ubuntu 20.04 and 22, as well in fedora 37?
I just loaded ubuntu-20.04.6-desktop-amd64.iso on a flash drive and repeated everything I did earlier, including appending the module_blacklist during boot, and got the same results.
That means this happened again:
  2. Select flash drive with live image of Ubuntu 20.04
  7. Select flash drive with live image of Ubuntu 20.04
This is starting to look like some hardware issue, isn’t it? :frowning:
Hi @Username009,
Yes looking like a hardware issue, are you still under warranty? might be worth opening a ticket. :slight_smile:
I think have the same issue with my device. core-i7 1360p running Ubuntu 23.04.
evtest does not show key presses for f7, f8, or f10, but they work until I put laptop into sleep mode. If it goes into sleep mode, those functions no longer work.
Since the functions work before going into sleep mode, it seems to me like it shouldn’t be a hardware issue?
My evtest output which looks similar to the others here:
$ sudo evtest
[sudo] password for jonathan:
Available devices:
/dev/input/event10:	Video Bus
/dev/input/event3:	FRMW0001:00 32AC:0006 Wireless Radio Control
/dev/input/event4:	FRMW0001:00 32AC:0006 Consumer Control
/dev/input/event6:	PIXA3854:00 093A:0274 Mouse
/dev/input/event7:	PIXA3854:00 093A:0274 Touchpad
/dev/input/event8:	ImExPS/2 Generic Explorer Mouse
/dev/input/event9:	Laptop Camera: Laptop Camera
Supported events:
      Value    250
      Value     33
Properties:
Event: time 1691008183.709540, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1691008183.709540, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1691008183.709540, -------------- SYN_REPORT ------------
Event: time 1691008188.614494, type 4 (EV_MSC), code 4 (MSC_SCAN), value ae
Event: time 1691008188.614494, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 1
Event: time 1691008188.614494, -------------- SYN_REPORT ------------
Event: time 1691008188.697491, type 4 (EV_MSC), code 4 (MSC_SCAN), value ae
Event: time 1691008188.697491, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 0
Event: time 1691008188.697491, -------------- SYN_REPORT ------------
Event: time 1691008189.220314, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1691008189.220314, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1
Event: time 1691008189.220314, -------------- SYN_REPORT ------------
Event: time 1691008189.340703, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1691008189.340703, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0
Event: time 1691008189.340703, -------------- SYN_REPORT ------------
Event: time 1691008189.857664, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90
Event: time 1691008189.857664, type 1 (EV_KEY), code 165 (KEY_PREVIOUSSONG), value 1
Event: time 1691008189.857664, -------------- SYN_REPORT ------------
Event: time 1691008190.002336, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90
Event: time 1691008190.002336, type 1 (EV_KEY), code 165 (KEY_PREVIOUSSONG), value 0
Event: time 1691008190.002336, -------------- SYN_REPORT ------------
Event: time 1691008191.315293, type 4 (EV_MSC), code 4 (MSC_SCAN), value a2
Event: time 1691008191.315293, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 1
Event: time 1691008191.315293, -------------- SYN_REPORT ------------
Event: time 1691008191.408348, type 4 (EV_MSC), code 4 (MSC_SCAN), value a2
Event: time 1691008191.408348, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 0
Event: time 1691008191.408348, -------------- SYN_REPORT ------------
Event: time 1691008192.016813, type 4 (EV_MSC), code 4 (MSC_SCAN), value 99
Event: time 1691008192.016813, type 1 (EV_KEY), code 163 (KEY_NEXTSONG), value 1
Event: time 1691008192.016813, -------------- SYN_REPORT ------------
Event: time 1691008192.102969, type 4 (EV_MSC), code 4 (MSC_SCAN), value 99
Event: time 1691008192.102969, type 1 (EV_KEY), code 163 (KEY_NEXTSONG), value 0
Event: time 1691008192.102969, -------------- SYN_REPORT ------------
Event: time 1691008194.413095, type 4 (EV_MSC), code 4 (MSC_SCAN), value db
Event: time 1691008194.413095, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 1
Event: time 1691008194.413095, -------------- SYN_REPORT ------------
Event: time 1691008194.413222, type 4 (EV_MSC), code 4 (MSC_SCAN), value 19
Event: time 1691008194.413222, type 1 (EV_KEY), code 25 (KEY_P), value 1
Event: time 1691008194.413222, -------------- SYN_REPORT ------------
Event: time 1691008194.508385, type 4 (EV_MSC), code 4 (MSC_SCAN), value 19
Event: time 1691008194.508385, type 1 (EV_KEY), code 25 (KEY_P), value 0
Event: time 1691008194.508385, -------------- SYN_REPORT ------------
Event: time 1691008194.508735, type 4 (EV_MSC), code 4 (MSC_SCAN), value db
Event: time 1691008194.508735, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 0
Event: time 1691008194.508735, -------------- SYN_REPORT ------------
Event: time 1691008209.089673, type 4 (EV_MSC), code 4 (MSC_SCAN), value b7
Event: time 1691008209.089673, type 1 (EV_KEY), code 99 (KEY_SYSRQ), value 1
Event: time 1691008209.089673, -------------- SYN_REPORT ------------
Event: time 1691008209.224798, type 4 (EV_MSC), code 4 (MSC_SCAN), value b7
Event: time 1691008209.224798, type 1 (EV_KEY), code 99 (KEY_SYSRQ), value 0
Event: time 1691008209.224798, -------------- SYN_REPORT ------------
Event: time 1691008212.555610, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1691008212.555610, type 1 (EV_KEY), code 28 (KEY_ENTER), value 1
Event: time 1691008212.555610, -------------- SYN_REPORT ------------
Event: time 1691008212.610728, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1691008212.610728, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1691008212.610728, -------------- SYN_REPORT ------------
Event: time 1691008215.898339, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1691008215.898339, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 1
Event: time 1691008215.898339, -------------- SYN_REPORT ------------
Event: time 1691008215.990433, type 4 (EV_MSC), code 4 (MSC_SCAN), value ed
Event: time 1691008215.990433, type 1 (EV_KEY), code 226 (KEY_MEDIA), value 0
Event: time 1691008215.990433, -------------- SYN_REPORT ------------
Event: time 1691008223.286015, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1691008223.286015, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1691008223.286015, -------------- SYN_REPORT ------------
Event: time 1691008223.445530, type 4 (EV_MSC), code 4 (MSC_SCAN), value 2e
Event: time 1691008223.445530, type 1 (EV_KEY), code 46 (KEY_C), value 1
Event: time 1691008223.445530, -------------- SYN_REPORT ------------
^C
Just trying to get related info, what does xinput look like on your system?
sudo xinput --list
If anybody is interested in an update, I’m still talking to support.
So far have I received a replacement input cover, but the issue still persists. It seems like a hardware issue somewhere else for now.
Solution was provided by devkev in this thread: [TRACKING] 12th gen not sending XF86MonBrightnessUp / Down - #67 by devkev
Thread can be closed
