FW13 Intel 13th, Ubuntu 22.04 LTS, Xfce desktop
I followed the instructions to disable the hid sensor, and I get the expected “blacklisted” message during boot. Screen brightness keys work at the login screen for Xfce desktop (my default), but after login they don’t work at all.
It’s a recent clean install of Ubuntu, with a few additions such as blueman, dropbox and the kate editor.
Has anyone seen similar, please?
Roops
My way to make it work is by explicitly binding those keys in my configuration.
So in /etc/acpi/handler.sh I have:
video/brightnessdown)
DISPLAY=:0.0 xbacklight -dec 1
logger 'brightness down'
video/brightnessup)
DISPLAY=:0.0 xbacklight -inc 1
logger 'brightness up'
And this is because I have an Artix Linux and am using acpid.
But since you are using Ubuntu instead, you should be able to add the shortcuts in the app xfce4-settings-editor by navigating to its section xfce4-keyboard-shortcuts, and add the bindings using the key names XF86MonBrightnessUp and XF86MonBrightnessDown.
What happens if you do Fn+Esc first? For me (Fedora) that switches the keyboard to the correct mode and brightness keys (and others) work without needing the Fn key pressed at the same time.
Thanks for the reply, but I couldn’t see which section in the text in xfce-settings-editor to add that.
I did find a fix, though–after installing xfce4-goodies I added xfce4-battery-plugin (to get % in the panel) and Power Manager, then under the Power Manager “General” tab I found “Handle display brightness keys” and turned it on, which works reliably with the previous tweak to disable hid_sensor_hub.
Thanks again
Roops
