@Anachron I’ll report back when it does it again. I had really wanted to play some games last night so I went ahead and reseated it as my usual practice and gamed the night away.
Edit: That didn’t take long. dmesg has some curious events. It explicitly mentions my enclosure by name and states that a card is recognized.
[Sun Apr 2 20:07:15 2023] thunderbolt 1-0:3.1: new retimer found, vendor=0x8087 device=0x15ee
[Sun Apr 2 20:07:16 2023] thunderbolt 1-3: new device found, vendor=0x283 device=0x1
[Sun Apr 2 20:07:16 2023] thunderbolt 1-3: Cooler Master Technology,Inc MasterCase EG200
[Sun Apr 2 20:07:16 2023] pcieport 0000:00:07.3: pciehp: Slot(6): Card present
[Sun Apr 2 20:07:16 2023] pcieport 0000:00:07.3: pciehp: Slot(6): Link Up
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: [8086:15ef] type 01 class 0x060400
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: enabling Extended Tags
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: supports D1 D2
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: PTM enabled, 4ns granularity
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.3 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: Adding to iommu group 18
[Sun Apr 2 20:07:16 2023] pcieport 0000:00:07.3: ASPM: current common clock configuration is inconsistent, reconfiguring
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: [8086:15ef] type 01 class 0x060400
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: enabling Extended Tags
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: supports D1 D2
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: Adding to iommu group 19
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: [8086:15ef] type 01 class 0x060400
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: enabling Extended Tags
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: supports D1 D2
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: Adding to iommu group 20
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: PCI bridge to [bus 7e-a5]
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: bridge window [io 0x0000-0x0fff]
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: bridge window [mem 0x00000000-0x000fffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: PCI bridge to [bus 7f-a5]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: bridge window [io 0x0000-0x0fff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: bridge window [mem 0x00000000-0x000fffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pci_bus 0000:7f: busn_res: [bus 7f-a5] end is updated to 7f
[Sun Apr 2 20:07:16 2023] pci 0000:80:00.0: [8086:15f0] type 00 class 0x0c0330
[Sun Apr 2 20:07:16 2023] pci 0000:80:00.0: reg 0x10: [mem 0x00000000-0x0000ffff]
[Sun Apr 2 20:07:16 2023] pci 0000:80:00.0: enabling Extended Tags
[Sun Apr 2 20:07:16 2023] pci 0000:80:00.0: supports D1 D2
[Sun Apr 2 20:07:16 2023] pci 0000:80:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Sun Apr 2 20:07:16 2023] pci 0000:80:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.3 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[Sun Apr 2 20:07:16 2023] pci 0000:80:00.0: Adding to iommu group 21
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: PCI bridge to [bus 80-a5]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: bridge window [io 0x0000-0x0fff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: bridge window [mem 0x00000000-0x000fffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pci_bus 0000:80: busn_res: [bus 80-a5] end is updated to 80
[Sun Apr 2 20:07:16 2023] pci_bus 0000:7e: busn_res: [bus 7e-a5] end is updated to 80
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: BAR 14: assigned [mem 0x52000000-0x5e1fffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: BAR 15: assigned [mem 0x6060000000-0x607bffffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: BAR 13: assigned [io 0x7000-0x8fff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: BAR 14: assigned [mem 0x52000000-0x580fffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: BAR 15: assigned [mem 0x6060000000-0x606dffffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: BAR 14: assigned [mem 0x58100000-0x5e1fffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: BAR 15: assigned [mem 0x606e000000-0x607bffffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: BAR 13: assigned [io 0x7000-0x7fff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: BAR 13: assigned [io 0x8000-0x8fff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: PCI bridge to [bus 7f]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: bridge window [io 0x7000-0x7fff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: bridge window [mem 0x52000000-0x580fffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:01.0: bridge window [mem 0x6060000000-0x606dffffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pci 0000:80:00.0: BAR 0: assigned [mem 0x58100000-0x5810ffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: PCI bridge to [bus 80]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: bridge window [io 0x8000-0x8fff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: bridge window [mem 0x58100000-0x5e1fffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7e:02.0: bridge window [mem 0x606e000000-0x607bffffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: PCI bridge to [bus 7e-80]
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: bridge window [io 0x7000-0x8fff]
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: bridge window [mem 0x52000000-0x5e1fffff]
[Sun Apr 2 20:07:16 2023] pci 0000:7d:00.0: bridge window [mem 0x6060000000-0x607bffffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pcieport 0000:00:07.3: PCI bridge to [bus 7d-a5]
[Sun Apr 2 20:07:16 2023] pcieport 0000:00:07.3: bridge window [io 0x7000-0x8fff]
[Sun Apr 2 20:07:16 2023] pcieport 0000:00:07.3: bridge window [mem 0x52000000-0x5e1fffff]
[Sun Apr 2 20:07:16 2023] pcieport 0000:00:07.3: bridge window [mem 0x6060000000-0x607bffffff 64bit pref]
[Sun Apr 2 20:07:16 2023] pcieport 0000:7d:00.0: enabling device (0000 -> 0003)
[Sun Apr 2 20:07:16 2023] pcieport 0000:7e:01.0: enabling device (0000 -> 0003)
[Sun Apr 2 20:07:16 2023] pcieport 0000:7e:02.0: enabling device (0000 -> 0003)
[Sun Apr 2 20:07:16 2023] pci 0000:80:00.0: enabling device (0000 -> 0002)
[Sun Apr 2 20:07:16 2023] xhci_hcd 0000:80:00.0: xHCI Host Controller
[Sun Apr 2 20:07:16 2023] xhci_hcd 0000:80:00.0: new USB bus registered, assigned bus number 5
[Sun Apr 2 20:07:16 2023] xhci_hcd 0000:80:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000200009810
[Sun Apr 2 20:07:16 2023] xhci_hcd 0000:80:00.0: new USB bus registered, assigned bus number 6
[Sun Apr 2 20:07:16 2023] xhci_hcd 0000:80:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[Sun Apr 2 20:07:16 2023] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[Sun Apr 2 20:07:16 2023] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Sun Apr 2 20:07:16 2023] usb usb5: Product: xHCI Host Controller
[Sun Apr 2 20:07:16 2023] usb usb5: Manufacturer: Linux 6.2.8-300.fc38.x86_64 xhci-hcd
[Sun Apr 2 20:07:16 2023] usb usb5: SerialNumber: 0000:80:00.0
[Sun Apr 2 20:07:16 2023] hub 5-0:1.0: USB hub found
[Sun Apr 2 20:07:16 2023] hub 5-0:1.0: 2 ports detected
[Sun Apr 2 20:07:16 2023] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[Sun Apr 2 20:07:16 2023] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Sun Apr 2 20:07:16 2023] usb usb6: Product: xHCI Host Controller
[Sun Apr 2 20:07:16 2023] usb usb6: Manufacturer: Linux 6.2.8-300.fc38.x86_64 xhci-hcd
[Sun Apr 2 20:07:16 2023] usb usb6: SerialNumber: 0000:80:00.0
[Sun Apr 2 20:07:16 2023] hub 6-0:1.0: USB hub found
[Sun Apr 2 20:07:16 2023] hub 6-0:1.0: 2 ports detected
[Sun Apr 2 20:07:21 2023] usb usb2-port4: attempt power cycle
[Sun Apr 2 20:07:30 2023] usb usb2-port4: unable to enumerate USB device
[Sun Apr 2 20:11:37 2023] pci_bus 0000:7f: Allocating resources
[Sun Apr 2 20:11:37 2023] pci_bus 0000:80: Allocating resources
[Sun Apr 2 20:14:05 2023] pci 0000:7f:00.0: [8086:4fa0] type 01 class 0x060400
[Sun Apr 2 20:14:05 2023] pci 0000:7f:00.0: reg 0x10: [mem 0x00000000-0x007fffff 64bit pref]
[Sun Apr 2 20:14:05 2023] pci 0000:7f:00.0: PME# supported from D0 D3hot D3cold
[Sun Apr 2 20:14:05 2023] pci 0000:7f:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.3 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[Sun Apr 2 20:14:05 2023] pci 0000:7f:00.0: Adding to iommu group 22
[Sun Apr 2 20:14:05 2023] pci 0000:7f:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Sun Apr 2 20:14:05 2023] pci_bus 0000:80: busn_res: [bus 80] end is updated to 80
[Sun Apr 2 20:14:05 2023] pci 0000:7f:00.0: devices behind bridge are unusable because [bus 80] cannot be assigned for them
[Sun Apr 2 20:14:05 2023] pcieport 0000:7e:01.0: bridge has subordinate 7f but max busn 80
[Sun Apr 2 20:14:05 2023] pci_bus 0000:7f: Allocating resources
[Sun Apr 2 20:14:05 2023] pci 0000:7f:00.0: BAR 0: assigned [mem 0x6060000000-0x60607fffff 64bit pref]
[Sun Apr 2 20:14:05 2023] pci_bus 0000:80: Allocating resources
[Sun Apr 2 20:14:05 2023] pcieport 0000:7f:00.0: enabling device (0000 -> 0002)
[Sun Apr 2 20:14:05 2023] pcieport 0000:7f:00.0: bridge configuration invalid ([bus 80-80]), reconfiguring
[Sun Apr 2 20:14:05 2023] pcieport 0000:7f:00.0: devices behind bridge are unusable because [bus 80] cannot be assigned for them
[Sun Apr 2 20:14:25 2023] thunderbolt 0000:00:0d.3: 0:3: failed to reach state TB_PORT_UP. Ignoring port...
[Sun Apr 2 20:14:25 2023] thunderbolt 0000:00:0d.3: 0:3: lost during suspend, disconnecting
[Sun Apr 2 20:14:25 2023] thunderbolt 1-0:3.1: retimer disconnected
[Sun Apr 2 20:14:25 2023] thunderbolt 1-3: device disconnected
[Sun Apr 2 20:14:26 2023] pcieport 0000:7d:00.0: not ready 1023ms after resume; giving up
[Sun Apr 2 20:14:26 2023] pcieport 0000:7d:00.0: Unable to change power state from D3cold to D0, device inaccessible
[Sun Apr 2 20:14:26 2023] pcieport 0000:00:07.3: pciehp: Slot(6): Card not present
[Sun Apr 2 20:14:26 2023] pcieport 0000:7e:01.0: Unable to change power state from D3cold to D0, device inaccessible
[Sun Apr 2 20:14:26 2023] pcieport 0000:7f:00.0: Unable to change power state from D3cold to D0, device inaccessible
[Sun Apr 2 20:14:26 2023] pcieport 0000:7e:02.0: Unable to change power state from D3cold to D0, device inaccessible
[Sun Apr 2 20:14:26 2023] xhci_hcd 0000:80:00.0: Unable to change power state from D3cold to D0, device inaccessible
[Sun Apr 2 20:14:26 2023] xhci_hcd 0000:80:00.0: Controller not ready at resume -19
[Sun Apr 2 20:14:26 2023] xhci_hcd 0000:80:00.0: PCI post-resume error -19!
[Sun Apr 2 20:14:26 2023] xhci_hcd 0000:80:00.0: HC died; cleaning up
[Sun Apr 2 20:14:26 2023] xhci_hcd 0000:80:00.0: remove, state 4
[Sun Apr 2 20:14:26 2023] usb usb6: USB disconnect, device number 1
[Sun Apr 2 20:14:26 2023] xhci_hcd 0000:80:00.0: USB bus 6 deregistered
[Sun Apr 2 20:14:26 2023] usb usb5: USB disconnect, device number 1
[Sun Apr 2 20:14:26 2023] xhci_hcd 0000:80:00.0: Host halt failed, -19
[Sun Apr 2 20:14:26 2023] xhci_hcd 0000:80:00.0: Host not accessible, reset failed.
[Sun Apr 2 20:14:26 2023] xhci_hcd 0000:80:00.0: USB bus 5 deregistered
[Sun Apr 2 20:14:26 2023] pci 0000:7f:00.0: Removing from iommu group 22
[Sun Apr 2 20:14:26 2023] pci_bus 0000:7f: busn_res: [bus 7f] is released
[Sun Apr 2 20:14:26 2023] pci 0000:7e:01.0: Removing from iommu group 19
[Sun Apr 2 20:14:26 2023] pci 0000:80:00.0: Removing from iommu group 21
[Sun Apr 2 20:14:26 2023] pci_bus 0000:80: busn_res: [bus 80] is released
[Sun Apr 2 20:14:26 2023] pci 0000:7e:02.0: Removing from iommu group 20
[Sun Apr 2 20:14:26 2023] pci_bus 0000:7e: busn_res: [bus 7e-80] is released
[Sun Apr 2 20:14:26 2023] pci 0000:7d:00.0: Removing from iommu group 18
[Sun Apr 2 20:14:34 2023] usb usb2-port4: attempt power cycle
Additionally, I managed to get the card to work without reseating it by power-cycling the enclosure. I had tried this before and it hadn’t worked so I’m not sure why it did now. And on top of that, attached peripherals were non-functional despite obviously receiving power until I reseated my USB-A expansion card that connects to the hub on the enclosure. All very odd to me.
