Hey guys;
This is regarding the Gen 12 Laptop 13, running Linux (in my case Ubuntu but many others have this problem as well).
I’ve been having no particular trouble with the onboard audio on my laptop since installing Ubuntu, but last night it abruptly stopped working. lspci would show the device, dmesg wasn’t reporting any problems, but it seemed like nothing could ‘talk’ to it. I even went into /dev/snd and tried to poke the devices there and I would get weird errors (sadly I don’t remember the message but it was something like ‘device can’t communicate’)
I went through all the advise on here, re-installing pulseaudio, messing with kernel modules, and nothing helped. I went through many reboots, including ‘halting’ the system and booting up fresh rather than just soft reboots.
I decided to open up the laptop and make sure the audio connection was secure from the motherboard to the sound board. Kind of a last ditch option. When I opened up the laptop, the red lights indicating the motherboard is still powered stayed on and wouldn’t turn off even after leaving it a few minutes.
I booted up, pressed F2 to get into BIOS, and used the option to turn off the battery there. When I exited BIOS, the laptop shut all the way off and the red lights went out.
Then I re-seated my ribbon cable to the audio break out board. It didn’t seem like it needed it, it was well secure. To boot again, I had to plug the laptop in to the power supply.
When I booted up, my audio device worked once again. Hooray! However, I don’t think it was re-seating the cable (though I guess it could have been). I think it was the extra-hard reboot of going through BIOS and ‘disconnecting’ the battery.
I’d like to suggest to anyone out there who’s tried everything and nothing’s worked to perhaps try going into bios, turning the battery off, then booting again and seeing if that fixes your problem. Especially if, like me, it just randomly stops working out of the blue.
Not sure if this is helpful, but throwing it up here anyway ![]()
