Disconnect from working dock, connect to not-working dock with another set of monitors and cables, the monitors are recognized with name and resolution, but not working:
[Apr20 18:06] usb 7-1: USB disconnect, device number 30
[ +0,000009] usb 7-1.3: USB disconnect, device number 31
[ +0,000003] usb 7-1.3.5: USB disconnect, device number 33
[ +0,010621] [drm] DM_MST: stopping TM on aconnector: 00000000c998c204 [id: 102]
[ +0,022321] usb 8-1: USB disconnect, device number 31
[ +0,000061] usb 8-1.3: USB disconnect, device number 32
[ +0,021185] r8152-cfgselector 8-1.4: USB disconnect, device number 33
[ +0,027000] r8152 8-1.4:1.0 enx605b3015a741: Stop submitting intr, status -108
[ +0,063273] usb 7-1.5: USB disconnect, device number 32
[ +9,148283] audit: type=1107 audit(1713629201.844:148): pid=2021 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="Properties>
exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
[Apr20 18:07] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-70)
[ +0,063441] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ +0,126965] workqueue: acpi_ec_event_processor hogged CPU for >10000us 32 times, consider switching to WQ_UNBOUND
[ +0,228912] [drm] DM_MST: starting TM on aconnector: 00000000c998c204 [id: 102]
[ +0,004173] [drm] DM_MST: DP14, 2-lane link detected
[ +0,154911] usb 7-1: new high-speed USB device number 34 using xhci_hcd
[ +0,156627] usb 7-1: New USB device found, idVendor=0bda, idProduct=5487, bcdDevice= 1.57
[ +0,000006] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000003] usb 7-1: Product: Dell dock
[ +0,000001] usb 7-1: Manufacturer: Dell Inc.
[ +0,007727] [drm] Downstream port present 1, type 0
[ +0,052545] hub 7-1:1.0: USB hub found
[ +0,001086] hub 7-1:1.0: 5 ports detected
[ +0,045797] [drm] Downstream port present 1, type 0
[ +0,016538] usb 8-1: new SuperSpeed Plus Gen 2x1 USB device number 34 using xhci_hcd
[ +0,021906] usb 8-1: New USB device found, idVendor=0bda, idProduct=0487, bcdDevice= 1.57
[ +0,000006] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000001] usb 8-1: Product: Dell dock
[ +0,000002] usb 8-1: Manufacturer: Dell Inc.
[ +0,027613] hub 8-1:1.0: USB hub found
[ +0,000256] hub 8-1:1.0: 4 ports detected
[ +0,004813] audit: type=1107 audit(1713629222.432:149): pid=2021 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="Properties>
[ +0,241069] usb 7-1.3: new high-speed USB device number 35 using xhci_hcd
[ +0,126373] usb 7-1.3: New USB device found, idVendor=0bda, idProduct=5413, bcdDevice= 1.22
[ +0,000008] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000003] usb 7-1.3: Product: Dell dock
[ +0,000002] usb 7-1.3: Manufacturer: Dell Inc.
[ +0,057702] hub 7-1.3:1.0: USB hub found
[ +0,001277] hub 7-1.3:1.0: 6 ports detected
[ +0,030792] usb 8-1.3: new SuperSpeed USB device number 35 using xhci_hcd
[ +0,042048] usb 8-1.3: New USB device found, idVendor=0bda, idProduct=0413, bcdDevice= 1.22
[ +0,000008] usb 8-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000002] usb 8-1.3: Product: Dell dock
[ +0,000002] usb 8-1.3: Manufacturer: Dell Inc.
[ +0,028426] hub 8-1.3:1.0: USB hub found
[ +0,001452] hub 8-1.3:1.0: 4 ports detected
[ +0,047919] usb 7-1.5: new high-speed USB device number 36 using xhci_hcd
[ +0,103751] usb 7-1.5: New USB device found, idVendor=413c, idProduct=b06e, bcdDevice= 1.01
[ +0,000006] usb 7-1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ +0,000003] usb 7-1.5: Product: Dell dock
[ +0,065190] hid-generic 0003:413C:B06E.0021: hiddev2,hidraw3: USB HID v1.11 Device [Dell dock] on usb-0000:c3:00.4-1.5/input0
[ +0,047040] usb 7-1.3.5: new high-speed USB device number 37 using xhci_hcd
[ +0,113042] usb 7-1.3.5: New USB device found, idVendor=413c, idProduct=b06f, bcdDevice= 1.01
[ +0,000009] usb 7-1.3.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ +0,000003] usb 7-1.3.5: Product: Dell dock
[ +0,069611] hid-generic 0003:413C:B06F.0022: hiddev4,hidraw6: USB HID v1.11 Device [Dell dock] on usb-0000:c3:00.4-1.3.5/input0
[ +3,505895] usb usb8-port1: Cannot enable. Maybe the USB cable is bad?
[ +0,000042] usb 8-1.3: USB disconnect, device number 35
[ +0,006914] hub 8-1:1.0: set hub depth failed
[ +0,104462] usb 8-1: Runtime PM usage count underflow!
[ +0,248920] [drm] enabling link 3 failed: 15
[ +0,012541] xhci_hcd 0000:c3:00.4: Device Notification event for unused slot 0
[ +0,062579] usb 8-1: USB disconnect, device number 34
[ +0,128131] usb 8-1: new SuperSpeed Plus Gen 2x1 USB device number 36 using xhci_hcd
[ +0,021995] usb 8-1: New USB device found, idVendor=0bda, idProduct=0487, bcdDevice= 1.57
[ +0,000004] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000003] usb 8-1: Product: Dell dock
[ +0,030518] hub 8-1:1.0: USB hub found
[ +0,000235] hub 8-1:1.0: 4 ports detected
[ +0,287800] usb 8-1.3: new SuperSpeed USB device number 37 using xhci_hcd
[ +0,038602] usb 8-1.3: New USB device found, idVendor=0bda, idProduct=0413, bcdDevice= 1.22
[ +0,000006] usb 8-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,028514] hub 8-1.3:1.0: USB hub found
[ +0,001427] hub 8-1.3:1.0: 4 ports detected
[ +0,084359] usb 8-1.4: new SuperSpeed USB device number 38 using xhci_hcd
[ +0,020731] usb 8-1.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.11
[ +0,000006] usb 8-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ +0,000002] usb 8-1.4: Product: USB 10/100/1000 LAN
[ +0,000002] usb 8-1.4: Manufacturer: Realtek
[ +0,000002] usb 8-1.4: SerialNumber: 111000001
[ +0,161244] r8152-cfgselector 8-1.4: reset SuperSpeed USB device number 38 using xhci_hcd
[ +0,052900] r8152 8-1.4:1.0: load rtl8153b-2 v2 04/27/23 successfully
[ +0,032936] r8152 8-1.4:1.0 eth0: v1.12.13
[ +0,051653] r8152 8-1.4:1.0 enx60189508074d: renamed from eth0
[ +3,534830] [drm] enabling link 3 failed: 15
Disconnect and reconnect Displayport, then switch over to dock number three with some more USB devices attached:
[Apr20 18:12] workqueue: drm_mode_rmfb_work_fn [drm] hogged CPU for >10000us 16 times, consider switching to WQ_UNBOUND
[Apr20 18:13] [drm] DM_MST: stopping TM on aconnector: 00000000c998c204 [id: 102]
[ +8,446243] audit: type=1107 audit(1713629606.843:150): pid=2021 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="Properties>
[Apr20 18:14] [drm] DM_MST: starting TM on aconnector: 00000000c998c204 [id: 102]
[ +0,003335] [drm] DM_MST: DP14, 2-lane link detected
[ +0,306022] [drm] Downstream port present 1, type 0
[ +0,058461] audit: type=1107 audit(1713629676.511:151): pid=2021 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="Properties>
[ +4,728997] [drm] enabling link 3 failed: 15
[Apr20 18:16] [drm] DM_MST: stopping TM on aconnector: 00000000c998c204 [id: 102]
[ +8,601674] audit: type=1107 audit(1713629781.844:152): pid=2021 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="Properties>
[ +13,181732] usb 7-1: USB disconnect, device number 34
[ +0,000008] usb 7-1.3: USB disconnect, device number 35
[ +0,000004] usb 7-1.3.5: USB disconnect, device number 37
[ +0,025538] usb 8-1: USB disconnect, device number 36
[ +0,000061] usb 8-1.3: USB disconnect, device number 37
[ +0,018623] r8152-cfgselector 8-1.4: USB disconnect, device number 38
[ +0,006204] r8152 8-1.4:1.0 enx60189508074d: Stop submitting intr, status -108
[ +0,101623] usb 7-1.5: USB disconnect, device number 36
[ +14,009017] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-70)
[ +0,379194] usb 7-1: new high-speed USB device number 38 using xhci_hcd
[ +0,084119] [drm] DM_MST: starting TM on aconnector: 00000000c998c204 [id: 102]
[ +0,004174] [drm] DM_MST: DP14, 2-lane link detected
[ +0,064293] usb 7-1: New USB device found, idVendor=0bda, idProduct=5487, bcdDevice= 1.47
[ +0,063055] hub 7-1:1.0: USB hub found
[ +0,000406] hub 7-1:1.0: 5 ports detected
[ +0,062608] usb 8-1: new SuperSpeed Plus Gen 2x1 USB device number 39 using xhci_hcd
[ +0,019451] usb 8-1: New USB device found, idVendor=0bda, idProduct=0487, bcdDevice= 1.47
[ +0,000009] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000002] usb 8-1: Product: Dell dock
[ +0,029937] hub 8-1:1.0: USB hub found
[ +0,000306] hub 8-1:1.0: 4 ports detected
[ +0,079314] [drm] Downstream port present 1, type 0
[ +0,099814] [drm] Downstream port present 1, type 0
[ +0,064458] usb 7-1.3: new high-speed USB device number 39 using xhci_hcd
[ +0,004931] audit: type=1107 audit(1713629810.144:153): pid=2021 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="Properties>
[ +0,115672] usb 7-1.3: New USB device found, idVendor=0bda, idProduct=5413, bcdDevice= 1.21
[ +0,000013] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,034722] hub 7-1.3:1.0: USB hub found
[ +0,001383] hub 7-1.3:1.0: 6 ports detected
[ +0,062489] usb 8-1.3: new SuperSpeed USB device number 40 using xhci_hcd
[ +0,034006] usb 8-1.3: New USB device found, idVendor=0bda, idProduct=0413, bcdDevice= 1.21
[ +0,000003] usb 8-1.3: Product: Dell dock
[ +0,035566] hub 8-1.3:1.0: USB hub found
[ +0,001978] hub 8-1.3:1.0: 4 ports detected
[ +0,033227] usb 7-1.5: new high-speed USB device number 40 using xhci_hcd
[ +0,103725] usb 7-1.5: New USB device found, idVendor=413c, idProduct=b06e, bcdDevice= 1.01
[ +0,000007] usb 7-1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ +0,049669] hid-generic 0003:413C:B06E.0023: hiddev2,hidraw3: USB HID v1.11 Device [Dell dock] on usb-0000:c3:00.4-1.5/input0
[ +0,042579] usb 7-1.3.2: new high-speed USB device number 41 using xhci_hcd
[ +0,117744] usb 7-1.3.2: New USB device found, idVendor=413c, idProduct=1010, bcdDevice=32.98
[ +0,000008] usb 7-1.3.2: New USB device strings: Mfr=0, Product=11, SerialNumber=0
[ +0,000003] usb 7-1.3.2: Product: USB 2.0 Hub [MTT]
[ +0,061682] hub 7-1.3.2:1.0: USB hub found
[ +0,001963] hub 7-1.3.2:1.0: 4 ports detected
[ +0,150639] usb 7-1.3.3: new full-speed USB device number 42 using xhci_hcd
[ +0,122570] usb 7-1.3.3: New USB device found, idVendor=046d, idProduct=c08e, bcdDevice=40.00
[ +0,000006] usb 7-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0,000003] usb 7-1.3.3: Product: MX518 Gaming Mouse
[ +0,000002] usb 7-1.3.3: Manufacturer: Logitech
[ +0,000001] usb 7-1.3.3: SerialNumber: 148838563730
[ +0,087148] input: Logitech MX518 Gaming Mouse as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.3/7-1.3.3:1.0/0003:046D:C08E.0024/input/input24
[ +0,000187] hid-generic 0003:046D:C08E.0024: input,hidraw6: USB HID v1.11 Mouse [Logitech MX518 Gaming Mouse] on usb-0000:c3:00.4-1.3.3/input0
[ +0,006046] usb 7-1.3.2.2: new low-speed USB device number 43 using xhci_hcd
[ +0,000990] input: Logitech MX518 Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.3/7-1.3.3:1.1/0003:046D:C08E.0025/input/input25
[ +0,059304] hid-generic 0003:046D:C08E.0025: input,hiddev4,hidraw15: USB HID v1.11 Keyboard [Logitech MX518 Gaming Mouse] on usb-0000:c3:00.4-1.3.3/input1
[ +0,065383] usb 7-1.3.2.2: New USB device found, idVendor=046d, idProduct=c625, bcdDevice= 4.05
[ +0,000006] usb 7-1.3.2.2: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ +0,000003] usb 7-1.3.2.2: Product: SpacePilot
[ +0,000002] usb 7-1.3.2.2: Manufacturer: 3Dconnexion
[ +0,062336] usb 7-1.3.5: new high-speed USB device number 44 using xhci_hcd
[ +0,111195] usb 7-1.3.5: New USB device found, idVendor=413c, idProduct=b06f, bcdDevice= 1.01
[ +0,000019] usb 7-1.3.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ +0,039076] hid-generic 0003:413C:B06F.0026: hiddev9,hidraw16: USB HID v1.11 Device [Dell dock] on usb-0000:c3:00.4-1.3.5/input0
[ +0,033835] usb 8-1.4: new SuperSpeed USB device number 41 using xhci_hcd
[ +0,020649] usb 8-1.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.11
[ +0,000003] usb 8-1.4: Product: USB 10/100/1000 LAN
[ +0,000001] usb 8-1.4: SerialNumber: 111000001
[ +0,013062] input: 3Dconnexion SpacePilot as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.2/7-1.3.2.2:1.0/0003:046D:C625.0027/input/input28
[ +0,058322] hid-generic 0003:046D:C625.0027: input,hidraw17: USB HID v1.10 Multi-Axis Controller [3Dconnexion SpacePilot] on usb-0000:c3:00.4-1.3.2.2/input0
[ +0,095275] r8152-cfgselector 8-1.4: reset SuperSpeed USB device number 41 using xhci_hcd
[ +0,049487] r8152 8-1.4:1.0: load rtl8153b-2 v2 04/27/23 successfully
[ +0,035687] r8152 8-1.4:1.0 eth0: v1.12.13
[ +0,015371] usb 7-1.3.2.4: new low-speed USB device number 45 using xhci_hcd
[ +0,049219] r8152 8-1.4:1.0 enx908d6e364ca6: renamed from eth0
[ +0,078416] usb 7-1.3.2.4: New USB device found, idVendor=413c, idProduct=2110, bcdDevice= 0.06
[ +0,000006] usb 7-1.3.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000002] usb 7-1.3.2.4: Product: Dell Wired Multimedia Keyboard
[ +0,000002] usb 7-1.3.2.4: Manufacturer: Dell
[ +0,106431] input: Dell Dell Wired Multimedia Keyboard as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.4/7-1.3.2.4:1.0/0003:413C:2110.0028/input/input29
[ +0,062749] hid-generic 0003:413C:2110.0028: input,hidraw18: USB HID v1.10 Keyboard [Dell Dell Wired Multimedia Keyboard] on usb-0000:c3:00.4-1.3.2.4/input0
[ +0,014238] input: Dell Dell Wired Multimedia Keyboard Mouse as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.4/7-1.3.2.4:1.1/0003:413C:2110.0029/input/input30
[ +0,000177] input: Dell Dell Wired Multimedia Keyboard System Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.4/7-1.3.2.4:1.1/0003:413C:2110.0029/input/input31
[ +0,056969] input: Dell Dell Wired Multimedia Keyboard Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.4/7-1.3.2.4:1.1/0003:413C:2110.0029/input/input32
[ +0,000218] hid-generic 0003:413C:2110.0029: input,hiddev10,hidraw19: USB HID v1.10 Mouse [Dell Dell Wired Multimedia Keyboard] on usb-0000:c3:00.4-1.3.2.4/input1
[ +1,214218] r8152 8-1.4:1.0 enx908d6e364ca6: carrier on
The Dell dock has two cables, both of which work as seen on dock number three. Disconnect plug one and connect plug two:
[Apr20 18:20] usb 7-1: USB disconnect, device number 38
[ +0,000009] usb 7-1.3: USB disconnect, device number 39
[ +0,000003] usb 7-1.3.2: USB disconnect, device number 41
[ +0,000002] usb 7-1.3.2.2: USB disconnect, device number 43
[ +0,012688] [drm] DM_MST: stopping TM on aconnector: 00000000c998c204 [id: 102]
[ +0,028475] usb 8-1: USB disconnect, device number 39
[ +0,000074] usb 8-1.3: USB disconnect, device number 40
[ +0,021761] r8152-cfgselector 8-1.4: USB disconnect, device number 41
[ +0,169409] usb 7-1.3.2.4: USB disconnect, device number 45
[ +0,672065] usb 7-1.3.3: USB disconnect, device number 42
[ +0,322259] usb 7-1.3.5: USB disconnect, device number 44
[ +0,125752] usb 7-1.5: USB disconnect, device number 40
[ +5,270316] usb 7-1: new high-speed USB device number 46 using xhci_hcd
[ +0,155331] usb 7-1: New USB device found, idVendor=0bda, idProduct=5487, bcdDevice= 1.47
[ +0,000007] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000002] usb 7-1: Product: Dell dock
[ +0,000002] usb 7-1: Manufacturer: Dell Inc.
[ +0,059496] hub 7-1:1.0: USB hub found
[ +0,000454] hub 7-1:1.0: 5 ports detected
[ +0,059923] [drm] DM_MST: starting TM on aconnector: 00000000c998c204 [id: 102]
[ +0,003827] usb 8-1: new SuperSpeed Plus Gen 2x1 USB device number 42 using xhci_hcd
[ +0,000318] [drm] DM_MST: DP14, 2-lane link detected
[ +0,022179] usb 8-1: New USB device found, idVendor=0bda, idProduct=0487, bcdDevice= 1.47
[ +0,000020] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000004] usb 8-1: Manufacturer: Dell Inc.
[ +0,025868] hub 8-1:1.0: USB hub found
[ +0,000286] hub 8-1:1.0: 4 ports detected
[ +0,239168] usb 7-1.3: new high-speed USB device number 47 using xhci_hcd
[ +0,018601] [drm] Downstream port present 1, type 0
[ +0,099900] usb 7-1.3: New USB device found, idVendor=0bda, idProduct=5413, bcdDevice= 1.21
[ +0,000006] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000214] [drm] Downstream port present 1, type 0
[ +0,041121] hub 7-1.3:1.0: USB hub found
[ +0,001302] hub 7-1.3:1.0: 6 ports detected
[ +0,031164] usb 8-1.3: new SuperSpeed USB device number 43 using xhci_hcd
[ +0,042255] usb 8-1.3: New USB device found, idVendor=0bda, idProduct=0413, bcdDevice= 1.21
[ +0,000007] usb 8-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,024374] hub 8-1.3:1.0: USB hub found
[ +0,001359] hub 8-1.3:1.0: 4 ports detected
[ +0,051699] usb 7-1.5: new high-speed USB device number 48 using xhci_hcd
[ +0,103622] usb 7-1.5: New USB device found, idVendor=413c, idProduct=b06e, bcdDevice= 1.01
[ +0,000009] usb 7-1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ +0,064650] hid-generic 0003:413C:B06E.002A: hiddev2,hidraw3: USB HID v1.11 Device [Dell dock] on usb-0000:c3:00.4-1.5/input0
[ +0,015807] usb 8-1.4: new SuperSpeed USB device number 44 using xhci_hcd
[ +0,020401] usb 8-1.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.11
[ +0,000007] usb 8-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ +0,000001] usb 8-1.4: Product: USB 10/100/1000 LAN
[ +0,079484] usb 7-1.3.2: new high-speed USB device number 49 using xhci_hcd
[ +0,118777] usb 7-1.3.2: New USB device found, idVendor=413c, idProduct=1010, bcdDevice=32.98
[ +0,000006] usb 7-1.3.2: New USB device strings: Mfr=0, Product=11, SerialNumber=0
[ +0,052561] hub 7-1.3.2:1.0: USB hub found
[ +0,001930] hub 7-1.3.2:1.0: 4 ports detected
[ +0,061743] r8152-cfgselector 8-1.4: reset SuperSpeed USB device number 44 using xhci_hcd
[ +0,049407] r8152 8-1.4:1.0: load rtl8153b-2 v2 04/27/23 successfully
[ +0,034150] r8152 8-1.4:1.0 eth0: v1.12.13
[ +0,013427] usb 7-1.3.3: new full-speed USB device number 50 using xhci_hcd
[ +0,038901] r8152 8-1.4:1.0 enx908d6e364ca6: renamed from eth0
[ +0,087979] usb 7-1.3.3: New USB device found, idVendor=046d, idProduct=c08e, bcdDevice=40.00
[ +0,000007] usb 7-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0,000002] usb 7-1.3.3: Product: MX518 Gaming Mouse
[ +0,000002] usb 7-1.3.3: SerialNumber: 148838563730
[ +0,069103] usb 7-1.3.2.2: new low-speed USB device number 51 using xhci_hcd
[ +0,038127] input: Logitech MX518 Gaming Mouse as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.3/7-1.3.3:1.0/0003:046D:C08E.002B/input/input33
[ +0,000238] hid-generic 0003:046D:C08E.002B: input,hidraw6: USB HID v1.11 Mouse [Logitech MX518 Gaming Mouse] on usb-0000:c3:00.4-1.3.3/input0
[ +0,006854] input: Logitech MX518 Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.3/7-1.3.3:1.1/0003:046D:C08E.002C/input/input34
[ +0,062996] hid-generic 0003:046D:C08E.002C: input,hiddev4,hidraw15: USB HID v1.11 Keyboard [Logitech MX518 Gaming Mouse] on usb-0000:c3:00.4-1.3.3/input1
[ +0,045721] usb 7-1.3.2.2: New USB device found, idVendor=046d, idProduct=c625, bcdDevice= 4.05
[ +0,062046] usb 7-1.3.5: new high-speed USB device number 52 using xhci_hcd
[ +0,111619] usb 7-1.3.5: New USB device found, idVendor=413c, idProduct=b06f, bcdDevice= 1.01
[ +0,000006] usb 7-1.3.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ +0,000002] usb 7-1.3.5: Product: Dell dock
[ +0,057097] hid-generic 0003:413C:B06F.002D: hiddev9,hidraw16: USB HID v1.11 Device [Dell dock] on usb-0000:c3:00.4-1.3.5/input0
[ +0,039522] input: 3Dconnexion SpacePilot as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.2/7-1.3.2.2:1.0/0003:046D:C625.002E/input/input37
[ +0,059981] hid-generic 0003:046D:C625.002E: input,hidraw17: USB HID v1.10 Multi-Axis Controller [3Dconnexion SpacePilot] on usb-0000:c3:00.4-1.3.2.2/input0
[Apr20 18:21] usb 7-1.3.2.4: new low-speed USB device number 53 using xhci_hcd
[ +0,122970] usb 7-1.3.2.4: New USB device found, idVendor=413c, idProduct=2110, bcdDevice= 0.06
[ +0,000008] usb 7-1.3.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0,000003] usb 7-1.3.2.4: Product: Dell Wired Multimedia Keyboard
[ +0,000003] usb 7-1.3.2.4: Manufacturer: Dell
[ +0,083280] input: Dell Dell Wired Multimedia Keyboard as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.4/7-1.3.2.4:1.0/0003:413C:2110.002F/input/input38
[ +0,058038] hid-generic 0003:413C:2110.002F: input,hidraw18: USB HID v1.10 Keyboard [Dell Dell Wired Multimedia Keyboard] on usb-0000:c3:00.4-1.3.2.4/input0
[ +0,013968] input: Dell Dell Wired Multimedia Keyboard Mouse as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.4/7-1.3.2.4:1.1/0003:413C:2110.0030/input/input39
[ +0,000121] input: Dell Dell Wired Multimedia Keyboard System Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.4/7-1.3.2.4:1.1/0003:413C:2110.0030/input/input40
[ +0,058488] input: Dell Dell Wired Multimedia Keyboard Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2.4/7-1.3.2.4:1.1/0003:413C:2110.0030/input/input41
[ +0,000152] hid-generic 0003:413C:2110.0030: input,hiddev10,hidraw19: USB HID v1.10 Mouse [Dell Dell Wired Multimedia Keyboard] on usb-0000:c3:00.4-1.3.2.4/input1
[ +0,496981] r8152 8-1.4:1.0 enx908d6e364ca6: carrier on
