[SOLVED] Samsung SSD 980 Pro firmware update on linux - how?
I am running debian stable on my gen 12 framework.
I want to update my Samsung SSD 980 Pro to firmware 5B2QGXA7, but the firmware is not available in LVFS.
I downloaded the .iso from samsung and tried to boot it, but the screen stays black. Some other users indicate that this iso only boots in legacy mode. I don’t have secure boot enabled and I have no idea how to apply this firmware update…
Any ideas?
Take a look here:
I will need to wait for the 990 Pro Firmware update to test this myself though.
I followed a similar guide to above (did not need to use a USB for booting just normal OS) all went well.
Thanks for those answers -it worked flawlessly!
I wonder why samsung cannot just release the folder with the update tool and the firmware binary. That seems to be all it takes to flash the firmware on linux.
Hi there,
Because we’re not all in ease with Linux, I just would like to share some more notes about the firmware update instructions mentioned which, indeed work great:
  1. To be able to use the smartctl command to check your ssd health, you must install smartmontools via this command: sudo apt-get install smartmontools
  2. to find your ssd name, in a terminal type df then copy the name of the files system mounted on the root
  3. to make the command sudo ./fumagician work, you must allow execution of the program: in the terminal, once in the folder of the program, type chmod +x fumagician
Now you’re good to go.
PS: i did it with the Samsung SSD 990 Pro
Oooh, the 990 Pro firmware finally dropped.
I will probably upgrade soon, even though my drive is unaffected.
Anyone knows how to do it on Fedora ?
@a_framework_owner there is no difference.
Wanted to say the instructions at this link (shared above by Usernames) worked for me with a Samsung 980 SSD. Thanks!
@Anachron Could you tell me if 990 pro works well under linux? Have you done perfomance tests? Did you manage to update the firmware without problems?
If you want to be 100% sure, let this be your guide. What storage (SSD) parts are compatible with the Framework Laptop?
@Danyal_Mugutdinov yes, it works for the 990 Pro under Linux and it should NOT be distro dependent.
My experience was pretty straight forward. Download the ISO from Samsung, mount the image, extract the Initial RAM disk, run the firmware update (just like the instructions posted here
Result
PS: Finally hit 1% used (before the firmware upgrade, don’t freak out lol)
Does anybody knows of any plans from samsung to ever use LVFS ?
They have an account but I think they already had one one year ago…
How do you understand :
 Is uploading firmware on behalf of other vendors
and
 Restricted to upload firmware for any hardware with vendor IDs:
    NVME:0x144D
    HSI:SAMSUNG ELECTRONICS CO., LTD.
i cursed their bootable iso and windows software also when it refused to find my drives set in raid from bios so i made a script to do this a bit easier.
then ran it from a live cd. but works fine if you have linux running also.
it will extrct the firmware from the bootable iso and tell you what to do.
It’s not necessary to check the firmware using smartctl. Quicker and easier to use GUI. At least if you are using the KDE DE.
Run Info Center in KDE
Scroll to SMART status
Select Show Details and you will something like the following which shows the firmware version.
Model Number: Samsung SSD 990 EVO Plus 1TB
Serial Number: -redacted-
Firmware Version: 2B2QKXG7
Amachron’s link is the easiest to follow.
Samsung’s disclaimer when upgrading is unecessairly scary.
It says updating will or may erase data.
I’m OK with may erase, but to start the message with will (like its a certainty) made me research like crazy before upgrading.
It just means backup your data, that’s all.
