So I have been hunting everywhere for a keychainable 2230 enclosure and had no luck. And every flash drive I look at has horrible write speeds past say 10gb or so.
I saw the framework storage card and it looks to be the perfect size for me. But I have a couple questions.
Specifically the 1TB model
How does the write speed hold up on sustained writes? As all the speed tests I see done are using the basic Crystal disk mark of 1gb. Im looking to use this to do image backups of computers and don’t want something that drops to 25MB/s writes after 10GB (Looking at you Luxe dual 512gb drive.) So if somebody has tested writing/copying 50-100gb+ I would love to know the results. Preferably on one that has the added cooling pad.
Is it USB 2 compatible with an adaptor? I know somebody mentioned using an A adaptor but I assume it was still a 3.x adaptor. Its rare but I sometimes would like to use it on servers with no usb 3.0
I get that I will have to fabricate a way to hook it to my keys.
And finally if you think I should be looking elsewhere at some other flash drive please point it out to me.
EDIT: Incase it matters I don’t have nor am planning on getting a framework soon. Were I in the market for a new laptop I would but I am not. Just looking for a quality but key chainable flash storage device.
