Laptop 16 speaker disconnecting issue, persistent as in multiple months
System: Ryzen™ 9 7940HS
Memory: DDR5-5600 - 64GB (2 x 32GB)
Storage: WD_BLACK™ SN770 NVMe™- M.2 2280 - 1TB
Operating System: Windows 11 Home (Download)
AMD Ryzen 9 7940HS w/ Radeon 780M Graphics, 4001 Mhz, 8 Core(s), 16 Logical Processor(s)
I’m having an issue with my speakers where if I hold my laptop at an angle the speakers seem to cut out, from what I can tell there still connected I think. mainly happens when I go to pick the laptop up from the front pad area, so possibly there is a bending happening in the frame and its loosening something. speakers will pop back on if I let it sit for a sec on flat surface. not sure what to do about it though, if it’s a manufacturing or hardware thing.
If anyone has suggestions on what I could do or test that would be great
