Hi guys, so I’ve just bought a Framework and I’m getting the topic headline on Windows Security. Anybody know if this is an issue, and also how I would go about solving it? Thanks in advance! Angel
What version of Windows are you using?
How did you install it?
Which model of Framework Laptop 13 do you have?
Windows 11.
I bought it on eBay so just booted up and installed. Assuming it came with, or the seller installed.
It’s the 13th gen with the i5 1340p
