Strange GPU usage while downloading
All I am doing at the moment is downloading visual studio and a game, how is there 100% GPU utilization? No other peripherals are plugged in and I am running the latest drivers and BIOS provided by Framework.
Try adding the GPU tab in the processes menu of task manager this way we can get more information. At the top bar, just right click and select the different GPU settings in view.
From the screenshots it’s unclear, which 100% usage you’re talking about. Could you clarify?
If talking about GPU1 100% usage on the first screenshot - this is just a quirk of AMD driver reporting the GPU usage. The GPU is actually fully off, and you can see, the temperature is basically cold, so it’s not really doing anything, just being reported by the driver as doing something and then Task Manager interprets this as 100% usage.
Thank you! This is what is was!
