Three small questions. Power button, disk drive, and charging
Hi, I got 3 more questions that may sound stupid, but I wanted to make sure because of what I saw with new computers and what I learned from the past.
Will it work with a plug in disk drive to the USB?
Can you still use it while its charging?
Is the power button a click button, or a finger print touch button? (I saw a video on the Framework laptop, and wasn’t sure what he did.)
To answer the questions:
Yes
Yes
Both. Press button to activate, touch finger to use the sensor.
Is the button like how you use an smartphone phone that has electrical signal senses that Knows you or your special gloves or special pen that it’s touching it, Or is it a finger print scanner like the mac laptops’ finger print key?
The button, that is the switch that powers on the laptop, I believe is a real physical push-to-click button. A switch known as a tactile or tact switch. And as such, it will respond as long as enough force is applied to click it.
The fingerprint reader portion is a separate device, technically fully independent from the power switch. Not certain if it’s capacitive-based (tiny electrical signal sensing), or optical-based, or otherwise. But either way, I wouldn’t expect it to work through gloves.
Fingerprint scanner is a “Goodix MOC Fingerprint Sensor” USB ID: 27c6:609c (connected via internal usb), in case you wish to google around & try to find what technology it uses.
thank you, I appreciate it! : )
