Touchpad doesn't work after waking
I use Fedora 34. When I put the laptop to sleep (closing the lid, etc.) and then wake it up, the touchpad doesn’t always work properly. The problem is more likely to occur after long sleeps than after short ones.
Sometimes the pointer won’t move, sometimes two finger scrolling won’t work, sometimes palm detection doesn’t work, sometimes button clicking doesn’t work. More than one of these issues usually happens, but I don’t think I’ve ever seen all things to fail at the same time.
Sleeping again doesn’t fix it, the only thing that does is rebooting. Has anyone else seen this? Any fixes?
Logout / Login again doesn’t help, but I’m not sure if that actually restarts X or not. I’ll try next time it happens.
@Matt_Ettus1 have you tried disabling PS2 Mouse emulation in the bios Advanced setting menu?
Thanks, that did fix it.
This recently (as in, it was previously fine) became an issue for me, but only after resuming from hibernation.
It was more consistent in my case: acceleration settings etc. lost, and scroll not working.
This seems to have fixed it for me too, as in I systemctl hibernated manually and changed the setting before allowing it to resume, and it’s now working. Time will tell I suppose - I don’t know why that would suddenly have become a problem @Kieran_Levin, I hadn’t changed it to ‘auto’?
I can only assume some package upgrade broke it, but I don’t know what that would be? I use sway, but restarting (as in completely killing it, not reloading config) it didn’t fix it when it happened. I notice the non-disabled option is ‘auto’ vs. ‘enabled’ say, is that because it’s up to something in software (or linux-firmware or something) whether to enable or not, and perhaps that changed recently?
Currently running into an extremely similar issue as OP and others are facing in which the trackpad won’t function unless I fully restart my machine. I’m running a Ryzen 7 7640U, and don’t see any similar option for PS2 Emulation in the BIOS for my board. Is there anything i’m missing or is the option now presently available? Currently running version BIOS version 3.03.
Did you get your issue resolved? I started a thread about a similar issue.
i have the same issue and i also cant find ps2 emulation in the bios i am on bios 3.05
Does something like
sudo rmmod i2c_hid_acpi && sudo modprobe i2c_hid_acpi
Fix it?
i don’t think that works for me i am on windows 11 23H2 Build 22631.4169
Seems weird for windows. I would contact support
i think i will, but do you know if there is a similar command on windows
It would be similar to enabling and disabling a device or driver. It shouldnt be the same issue. All you should have to do on Windows is make sure you installed the appropriate driver package from Framework.
i have the driver bundle and all the devices enabled
Same issue on one of my laptops.
I have a Framework 13 i7 and Framework 13 Ryzen. Both running Ubuntu 24.04.
Ryzen Framework experiences mouse freeze (both touchpad and mouse) after sleep.
I’ll attempt to reload the i2c drivers via the provided
command next time this happens.
I would like to understand if this is a known bug from the Framework team.
Thanks, that fixed my issue.
In my case, the symptoms were like the “finger counter” was off by one: I needed 2 fingers to move the cursor and 3 to scroll.
