I have the same issue.
Fedora 39, Ryzen 7 7840u, 16GB/512GB Prebuilt
I’m only using the web browser with a couple of tabs
Been seeing this happen on mine since day 1.
Doing nothing fan quiet, fan spikes high for 1 second, fan off.
It is rather odd and can be jarring when working quietly.
OS: Ubuntu 22.04.3 LTS x86_64
DE: Unity
CPU: AMD Ryzen 7 7840U
Memory: 31266MiB
I just received my fw13 amd ryzen 5. And the fan has been going up and down abruptly a lot. For the 2 hours that the device has been on. The fan has been loud for the 99% of the time. I thought the amd version was quiet.
Update: the fan quieted itself after all the drivers have been installed.
Just wanted to mention, that I have the same issue on my FW 13 AMD Ryzen 5. I’m on Ubuntu 22.04.03.
Same issue for me, the fan seems to jump to full speed for 1 second and back down. AMD Ryzen 7 with EndeavourOS with kernel 6.7.3-arch1-2
It’s been about 3 months since this issue has been reported and many Framework AMD users seem to be affected by it.
Is there any update on resolving the bug? I’d highly appreciate it!
This is something the engineering team is working on. Firmware specifically.
Will this benefit windows users too? Also having the same issue but on windows 11 OS.
It is firmware, so it will have an impact on the hardware regardless of the OS.
I have the same problem and it is really annoying for me and for my colleagues in the office.
How confident are you that this issue will be resolved?
I’m still within the return period on my device and as much as I like the Framework for all its other features and qualities, this is a bit of a deal breaker for me.
Hi, I have a new Framework 13 AMD and noticed this issue too on Windows 11. I updated to BIOS 3.05 just now, and the issue remains. I am doing nothing demanding, I have HWiNFO64 open to monitor the CPU temperatures, there are no spikes visible, and suddenly Framework turns on the fan to high speed for about 1 second, and then they turn off completely again.
What can we do to help you debug and fix this issue?
It is clearly a bug, because when I run benchmarks that make the CPU go to 95°C, the fans take about 30 seconds to turn on and stay on for quite a while. So where are these sudden fan spikes coming from when the system is in idle?
I updated to the 3.05 bios and I’m still experiencing this.
@Matt_Hartley Is it safe to assume that this is still in-progress for the firmware eng team?
Also, given the latest Framework email announcing more dedicated engineering teams, I assume there’ll be more frequent firmware fixes coming?
I’m seeing the same with my Framework 13 AMD on Ubuntu. At random points the fan will kick into high for maybe a second and then reduce fan speed again immediately. I’m on the latest bios version as well.
This is not a bug, but whether it’s desired is up to interpretation.
update edit
I found a way to replicate this. The “turn off completely again” is actually turned to 3% (the lowest PWM) then 0%.
If you are in a cold environment and just benchmark the CPU i.e sensor temperature passes the fan_off temp quickly, the fan will speed up gradually and if you then stop the benchmarking the CPU will slow down smoothly untli a complete stop.
However, if you are in a warm environment doing nothing demanding, the sensor’s temperature might stay at exactly at the fan_off i.e 313K for local_f75303@4d and/or 319K for cpu_f75303@4d and if the temperature changes very very slowly i.e. changing from 312K to 313K or from 313K to 314K in several minutes, the fan controller might freak out, sending 100% PWM in a fracton of second.
I am observing the same thing. It is happening when the local sensor temperature is around 40°C, which is the threshold for fan activation. However, sometimes it turns the fan on silently, keeping it around 2500 rpm, and sometimes it seems to spin up a lot only to reach the fan off threshold immediately and turn them off again. This then results in the weird on/off pulsating behavior.
There might be 2 problems at play at the same time:
- The fan is temporarily set for a higher RPM than it should be (way above 2500 rpm, which would correspond to the 40-41°C).
- The EC needs to use a higher hysteresis. I think they use a 0.5°C right now, which is simply not enough. In other laptops, the fans usually turn on and off at very different temperatures, e.g., turn on at 45°C and turn off at 40°C. This would solve the constant pulsating as well.
I think @Kieran_Levin is the person who could shed some light into this issue. He’s signed off on this EC commit that touches fan behavior, including the hysteresis, timeout, and RPM / fan duty adjustments. I believe we could 1) increase the hysteresis, and 2) make sure that the fan does not spin up too fast if it was previously off.
If you’re still seeing this and can provide steps to achieve this, please open a ticket and ask it to be sent to me to vet it and then I can escalate to engineering once we have the steps to repro and have it in the ticketing system.
It is actually very easy to reproduce for me, it happens whenever the temperature sensor is around 40°C, which is the fan activation threshold.
I got in touch with support and they asked me to kindly provide a video of the issue with a removed input cover, zoomed in on the fan. They would like to see the fan turning on at high RPM and immediately down again on the video.
I do not have time to do these experiments right now, but if anyone here has the time, please upload the video to YouTube and send a link here, and either send it to support or I would forward it to support myself!
I think I found where the bug is
$ sudo ectool temps all
--sensor name -------- temperature -------- ratio (fan_off and fan_max) --
local_f75303@4d 314 K (= 41 C) 3% (313 K and 343 K)
cpu_f75303@4d 318 K (= 45 C) 0% (319 K and 327 K)
ddr_f75303@4d 313 K (= 40 C) N/A (fan_off=401 K, fan_max=401 K)
cpu@4c 329 K (= 56 C) 0% (376 K and 378 K)
$ sudo ectool pwmgetfanrpm
Fan 0 RPM: 2229
$ sudo ectool fanduty 3
Fan duty cycle set for all fans.
Fan 0 RPM: 0
$ sudo ectool fanduty 10
Fan 0 RPM: 980
As shown, there are two sensors responsible of the fan speed, the local_f75303@4d and thecpu_f75303@4d. The temperature sensor can only output intergers. Thus the first sensors output 3% per C, the second ones output 12.5% per C. However if you $ sudo ectool fanduty 10 then $ sudo ectool pwmgetfanrpm and change the 10 to other value, you discover that the fan RPM is 0 if the duty cycle is at or below 10%. Thus for the fan controller to work as these temperatures, the first sensor might output an arbitary value when the temperature is below 316K, since in 314K the fanduty us 3% but there’s no way that the fan is spinning at 3% duty, and the fan is more like 20% duty actually
local_f75303@4d 319 K (= 46 C) 20% (313 K and 343 K)
cpu_f75303@4d 323 K (= 50 C) 50% (319 K and 327 K)
ddr_f75303@4d 310 K (= 37 C) N/A (fan_off=401 K, fan_max=401 K)
cpu@4c 369 K (= 96 C) 0% (376 K and 378 K)
local_f75303@4d 320 K (= 47 C) 23% (313 K and 343 K)
cpu_f75303@4d 324 K (= 51 C) 62% (319 K and 327 K)
cpu@4c 367 K (= 94 C) 0% (376 K and 378 K)
This also explains that why the fan appears to be spinning up and down when gaming, when gaming, the second sensor is hotter than the first sensor. Due to the window is narrower on the second sensor, the fan speed is changing 12.5% when the temperature is 1C hotter or cooler, this is very noticable, it feels like the fan motor is controlled by bypassing resistor banks instead of PWM, but actually it’s PWM. If you $ sudo ectool fanduty 80 then 81, 82, 83,… 90 you’ll find the fan speed completely not noticable, and if you from 90 back to 85 then 80 the noise change is barely noticable.
I am seeing this behavior on my Framework 13 11th Gen Intel laptop. Is this issue specific to AMD laptops, or will my laptop benefit from the future ec firmware fixes, too?
