Hi,
My external display stopped working with the latest kernel in Fedora 38 (workstation), kernel-core-6.4.15-200.fc38.x86_64. I rolled back this morning, and it’s working fine, but wanted y’all to be aware.
Hi,
This is helpful and will be added to the tracker today- which kernel release is working and, how are you connected to the external display?
Usually regressions like this involve a hub.
It’s working on kernel-core-6.4.14-200.fc38.x86_64, and I’m connected through HDMI.
Hi @Ben_Gifford , thanks for the heads up, Will check on 12th and 11th as well. See if same symptoms occur.
cheers
