[TRACKING] USB-A an ongoing problem?
@Matt_Hartley FWIW, i’m now on linux 6.7.0 and the problem as described in [1] appears to have gone. That is, i’m running the updated kernel for a few hours now, haven’t yet resumed from suspend, etc… But so far it’s looking good… Furthermore, the front right USB-A port now appears to recognize some devices which, iirc, it did not before ( in this specific port)…
[1] [TRACKING] USB-A an ongoing problem? - #36 by sydney
Appreciate the update and delighted to hear you found a path forward.
I batch write lots of video files to external drives on a weekly basis, usually around 140GB, and occasionally transfer between external drives up to 1TB. I had tons of issues with drives disconnecting or dropping speeds to dismal levels (had some help from my post here).
USB Tree View helped me figure out that one brand of external drive enclosure wasn’t communicating properly, and wouldn’t get the correct amount of power as a result, but properly working drives had connection issues too. However, using a powered USB hub has solved all my issues on my batch 5 framework 13. Sure, the problem is still there, but at least there is a reliable work around.
That was the exact setup I had:
HDMI lower left and USB-A lower right.
Swapped them and the error stopped.
I’m on NixOS with kernel 6.6.30
I’m running Arch Linux on an AMD 7840U. With kernel 6.9.1-zen (and regular 6.9.1), I get this exact error whenever I try to just power a device with a USB-A port, no matter where it is placed. Devices like flash drives are recognized and work just fine, but this error shows up whenever I want to charge a device or if I want to power an SBC.
Everything works perfectly if I use linux-lts (6.6.31-1-lts)
I think I have the issue you are describing here. I have the USB A port connected to a fully populated 7 port USB hub with an auxiliary power supply. The current draw from the framework-16 is 0.19 to 0.22 milliamps.
jeffs@frmwk16:~$ lsusb --tree
/:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 10000M
/:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 10000M
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 10000M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
    |__ Port 1: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
    |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/3p, 10000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/5p, 480M
    |__ Port 1: Dev 2, If 0, Class=, Driver=, 12M
    |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 3: Dev 34, If 0, Class=Hub, Driver=hub/4p, 480M
            |__ Port 1: Dev 35, If 0, Class=Hub, Driver=hub/4p, 480M
                |__ Port 2: Dev 37, If 0, Class=Hub, Driver=hub/4p, 480M
                |__ Port 4: Dev 40, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 2: Dev 36, If 0, Class=Hub, Driver=hub/4p, 480M
                |__ Port 3: Dev 39, If 0, Class=Hub, Driver=hub/4p, 480M
                |__ Port 4: Dev 42, If 0, Class=Printer, Driver=usblp, 12M
            |__ Port 3: Dev 38, If 0, Class=Hub, Driver=hub/4p, 480M
                |__ Port 1: Dev 43, If 0, Class=Hub, Driver=hub/4p, 480M
                    |__ Port 1: Dev 47, If 0, Class=, Driver=, 480M
                    |__ Port 1: Dev 47, If 1, Class=, Driver=, 480M
                    |__ Port 1: Dev 47, If 2, Class=, Driver=, 480M
                    |__ Port 1: Dev 47, If 3, Class=Mass Storage, Driver=usb-storage, 480M
                    |__ Port 2: Dev 50, If 0, Class=Audio, Driver=snd-usb-audio, 12M
                    |__ Port 2: Dev 50, If 1, Class=Audio, Driver=snd-usb-audio, 12M
                    |__ Port 2: Dev 50, If 2, Class=Audio, Driver=snd-usb-audio, 12M
                    |__ Port 2: Dev 50, If 3, Class=Human Interface Device, Driver=usbhid, 12M
                |__ Port 2: Dev 46, If 0, Class=Video, Driver=uvcvideo, 480M
                |__ Port 2: Dev 46, If 1, Class=Video, Driver=uvcvideo, 480M
                |__ Port 2: Dev 46, If 2, Class=Audio, Driver=snd-usb-audio, 480M
                |__ Port 2: Dev 46, If 3, Class=Audio, Driver=snd-usb-audio, 480M
            |__ Port 4: Dev 41, If 0, Class=Hub, Driver=hub/4p, 480M
    |__ Port 3: Dev 4, If 0, Class=Hub, Driver=hub/3p, 480M
    |__ Port 4: Dev 5, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 7, If 0, Class=Vendor Specific Class, Driver=, 12M
        |__ Port 3: Dev 8, If 0, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 3: Dev 8, If 1, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 3: Dev 8, If 2, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 3: Dev 8, If 3, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 5: Dev 6, If 0, Class=Wireless, Driver=btusb, 480M
    |__ Port 5: Dev 6, If 1, Class=Wireless, Driver=btusb, 480M
    |__ Port 5: Dev 6, If 2, Class=Wireless, Driver=, 480M
jeffs@frmwk16:~$ type or paste code here
If I attempt to boot with the 7 port hub plugged in, nothing happens. No error message, no boot text, nothing. However, if I unplug the hub from the framework-16, there is a normal boot. If I plug in the hub after linux has started but before mate or gnome start, then the USB bus starts normally.
[Thu Jun 13 17:24:38 2024] usb 1-2.3: new high-speed USB device number 34 using xhci_hcd
[Thu Jun 13 17:24:38 2024] usb 1-2.3: New USB device found, idVendor=214b, idProduct=7250, bcdDevice= 1.00
[Thu Jun 13 17:24:38 2024] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Thu Jun 13 17:24:38 2024] usb 1-2.3: Product: USB2.0 HUB
[Thu Jun 13 17:24:38 2024] hub 1-2.3:1.0: USB hub found
[Thu Jun 13 17:24:38 2024] usb 1-2.3.1: new high-speed USB device number 35 using xhci_hcd
[Thu Jun 13 17:24:39 2024] usb 1-2.3.1: New USB device found, idVendor=214b, idProduct=7250, bcdDevice= 1.00
[Thu Jun 13 17:24:39 2024] usb 1-2.3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Thu Jun 13 17:24:39 2024] usb 1-2.3.1: Product: USB2.0 HUB
[Thu Jun 13 17:24:39 2024] hub 1-2.3.1:1.0: USB hub found
[Thu Jun 13 17:24:39 2024] usb 1-2.3.2: new high-speed USB device number 36 using xhci_hcd
[Thu Jun 13 17:24:39 2024] usb 1-2.3.2: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 9.01
[Thu Jun 13 17:24:39 2024] usb 1-2.3.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Thu Jun 13 17:24:39 2024] usb 1-2.3.2: Product: USB2.0 Hub
[Thu Jun 13 17:24:39 2024] hub 1-2.3.2:1.0: USB hub found
[Thu Jun 13 17:24:39 2024] usb 1-2.3.1.2: new high-speed USB device number 37 using xhci_hcd
[Thu Jun 13 17:24:39 2024] usb 1-2.3.1.2: New USB device found, idVendor=0451, idProduct=8043, bcdDevice= 1.00
[Thu Jun 13 17:24:39 2024] usb 1-2.3.1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[Thu Jun 13 17:24:39 2024] usb 1-2.3.1.2: SerialNumber: 7B0108517C41
[Thu Jun 13 17:24:39 2024] hub 1-2.3.1.2:1.0: USB hub found
[Thu Jun 13 17:24:39 2024] usb 1-2.3.3: new high-speed USB device number 38 using xhci_hcd
[Thu Jun 13 17:24:39 2024] usb 1-2.3.3: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[Thu Jun 13 17:24:39 2024] usb 1-2.3.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Thu Jun 13 17:24:39 2024] usb 1-2.3.3: Product: USB 2.0 Hub
[Thu Jun 13 17:24:39 2024] hub 1-2.3.3:1.0: USB hub found
[Thu Jun 13 17:24:39 2024] usb 1-2.3.2.3: new high-speed USB device number 39 using xhci_hcd
[Thu Jun 13 17:24:39 2024] usb 1-2.3.2.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 9.01
[Thu Jun 13 17:24:39 2024] usb 1-2.3.2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Thu Jun 13 17:24:39 2024] usb 1-2.3.2.3: Product: USB2.0 Hub
[Thu Jun 13 17:24:39 2024] hub 1-2.3.2.3:1.0: USB hub found
[Thu Jun 13 17:24:39 2024] usb 1-2.3.1.4: new low-speed USB device number 40 using xhci_hcd
[Thu Jun 13 17:24:40 2024] usb 1-2.3.1.4: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00
[Thu Jun 13 17:24:40 2024] usb 1-2.3.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Thu Jun 13 17:24:40 2024] usb 1-2.3.1.4: Product: USB Optical Mouse
[Thu Jun 13 17:24:40 2024] usb 1-2.3.1.4: Manufacturer: Logitech
[Thu Jun 13 17:24:40 2024] usb 1-2.3.4: new high-speed USB device number 41 using xhci_hcd
[Thu Jun 13 17:24:40 2024] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-2/1-2.3/1-2.3.1/1-2.3.1.4/1-2.3.1.4:1.0/0003:046D:C077.000A/input/input18
[Thu Jun 13 17:24:40 2024] hid-generic 0003:046D:C077.000A: input,hidraw6: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:c1:00.3-2.3.1.4/input0
[Thu Jun 13 17:24:40 2024] usb 1-2.3.4: New USB device found, idVendor=2148, idProduct=7022, bcdDevice= 1.00
[Thu Jun 13 17:24:40 2024] usb 1-2.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Thu Jun 13 17:24:40 2024] usb 1-2.3.4: Product: USB2.0 HUB
[Thu Jun 13 17:24:40 2024] hub 1-2.3.4:1.0: USB hub found
[Thu Jun 13 17:24:40 2024] usb 1-2.3.2.4: new full-speed USB device number 42 using xhci_hcd
[Thu Jun 13 17:24:40 2024] usb 1-2.3.3.1: new high-speed USB device number 43 using xhci_hcd
[Thu Jun 13 17:24:40 2024] usb 1-2.3.2.4: New USB device found, idVendor=04f9, idProduct=000d, bcdDevice= 1.00
[Thu Jun 13 17:24:40 2024] usb 1-2.3.2.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Thu Jun 13 17:24:40 2024] usblp0: Disabling reads from problematic bidirectional printer
[Thu Jun 13 17:24:40 2024] usblp 1-2.3.2.4:1.0: usblp3: USB Unidirectional printer dev 42 if 0 alt 0 proto 2 vid 0x04F9 pid 0x000D
[Thu Jun 13 17:24:40 2024] usb 1-2.3.3.1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[Thu Jun 13 17:24:40 2024] usb 1-2.3.3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Thu Jun 13 17:24:40 2024] usb 1-2.3.3.1: Product: USB 2.0 Hub
[Thu Jun 13 17:24:41 2024] hub 1-2.3.3.1:1.0: USB hub found
[Thu Jun 13 17:24:42 2024] usb 1-2.3.4-port1: Cannot enable. Maybe the USB cable is bad?
[Thu Jun 13 17:24:43 2024] usb 1-2.3.4-port1: Cannot enable. Maybe the USB cable is bad?
[Thu Jun 13 17:24:43 2024] usb 1-2.3.4-port1: attempt power cycle
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.2: new high-speed USB device number 46 using xhci_hcd
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.2: New USB device found, idVendor=046d, idProduct=0991, bcdDevice= 0.08
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.2: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.2: SerialNumber: 8251C524
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.2: Found UVC 1.00 device <unnamed> (046d:0991)
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.1.1: new high-speed USB device number 47 using xhci_hcd
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.1.1: config 1 interface 1 altsetting 0 has a duplicate endpoint with address 0x81, skipping
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.1.1: config 1 interface 1 altsetting 0 has a duplicate endpoint with address 0x1, skipping
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.1.1: config 1 interface 1 altsetting 1 has a duplicate endpoint with address 0x81, skipping
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.1.1: config 1 interface 1 altsetting 1 has a duplicate endpoint with address 0x1, skipping
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.1.1: New USB device found, idVendor=1d5c, idProduct=2000, bcdDevice= 2.00
[Thu Jun 13 17:24:43 2024] usb 1-2.3.3.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Thu Jun 13 17:24:43 2024] usb-storage 1-2.3.3.1.1:1.3: USB Mass Storage device detected
[Thu Jun 13 17:24:43 2024] scsi host0: usb-storage 1-2.3.3.1.1:1.3
[Thu Jun 13 17:24:44 2024] usb 1-2.3.3.2: set resolution quirk: cval->res = 384
[Thu Jun 13 17:24:45 2024] usb 1-2.3.4-port1: Cannot enable. Maybe the USB cable is bad?
[Thu Jun 13 17:24:46 2024] usblp3: removed
[Thu Jun 13 17:24:46 2024] usblp0: Disabling reads from problematic bidirectional printer
[Thu Jun 13 17:24:46 2024] usb 1-2.3.4-port1: Cannot enable. Maybe the USB cable is bad?
[Thu Jun 13 17:24:46 2024] usb 1-2.3.4-port1: unable to enumerate USB device
[Thu Jun 13 17:24:46 2024] usblp 1-2.3.2.4:1.0: usblp3: USB Unidirectional printer dev 42 if 0 alt 0 proto 2 vid 0x04F9 pid 0x000D
[Thu Jun 13 17:24:46 2024] usb 1-2.3.3.1.2: new full-speed USB device number 50 using xhci_hcd
[Thu Jun 13 17:24:46 2024] usb 1-2.3.3.1.2: New USB device found, idVendor=0d8c, idProduct=013c, bcdDevice= 1.00
[Thu Jun 13 17:24:46 2024] usb 1-2.3.3.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Thu Jun 13 17:24:46 2024] usb 1-2.3.3.1.2: Product: USB PnP Sound Device
[Thu Jun 13 17:24:46 2024] usb 1-2.3.3.1.2: Manufacturer: C-Media Electronics Inc.
[Thu Jun 13 17:24:46 2024] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3.1/1-2.3.3.1.2/1-2.3.3.1.2:1.3/0003:0D8C:013C.000B/input/input19
[Thu Jun 13 17:24:46 2024] hid-generic 0003:0D8C:013C.000B: input,hidraw7: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-0000:c1:00.3-2.3.3.1.2/input3
[Thu Jun 13 17:25:19 2024] usb 1-2.3.3.1.1: reset high-speed USB device number 47 using xhci_hcd
[Thu Jun 13 17:25:51 2024] usb 1-2.3.3.1.1: reset high-speed USB device number 47 using xhci_hcd
jeffs@frmwk16:~$
What other information would be helpful for troubleshooting? Many thanks.
Do the same limitations apply to the Intel 12th gen board? Interesting that this article is specific to the AMD release.
@Jeff_Silverman
Does the problem change depending on which of the 6 slots on the FW16 you plug the “fully populated 7 port USB hub” into? I.e. in some slots it works, in others it fails.
Slot 1, 2, 3, 4, 5, or 6 ?
Sorry for the delay in getting back to you. I try the experiment tomorrow.
Jeff
I am trying to reproduce the problem and failing. What I do get is that there is an overcurrent condition, but that’s if I grossly overload it. My understanding of the USB standard is that it will shut down a port if it attempts to draw too much current. I know that the system will boot properly if I draw .40 amps.
At the moment, I have my 7-port USB hub plugged into the slot closest to me on the left side. The HDMI adapter is plugged into the middle socket in the left side.
The power is plugged into the right side on the slot farthest away from me. All of the other sockets are empty. How are the slots numbered, please?
For numbering of slots:
Framework 13 slots:
Framework 16 slots:
This, or similar issue just hit me as well, so adding to the flock, 3.19 BIOS.
  • AMD 7640
  • Switching expansion slot does not change the observed behaviour
  • Does not seem to happen on non-Framework computers
  • Used “Other World Computing Thunderbolt Hub”
  • Just created a ticket with more details as suggested
Happens on both Alpine Linux and Chimera, messages like
xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
ucsi_acpi USBC000:00: unknown error 0
ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
are seen when connecting an USB device (in this case, a portable display) fails.
I have one of four acting up but, also the first person to seriously use it and ride it all day long. i gave them proper usb a to c cable vs a micro to c adapter and micro cable they were using but, the issue can happen with a myriad of other devices they use. none of the other FW16s have been acting up. swapping cards around fixes it for a short period of time.
just delving in to this. i hope its not a mobo hardware issue that isn’t discovered till after warranty expires. (with dell i can get 4 year warranty just can’t buy new dell batteries after 4 years)
fw16 latest bios as of several weeks ago when i deployed it.
EDIT: I have another user with similar setup trying to duplicate the first users usb issues. both have a FW16. the one trying to reproduce the issue has not had issues before.
Thank you for sharing your experience! I have been seeing the same spam in my logs (October 2024 batch 13 inch AMD, Fedora 40). Unplugging the HDMI card from the lower left port also caused this spam to end.
I just purchased a FW13 AMD 7040 series and been hit by this issue (xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot).
I have USB-C on ports #1 and #3 and USB-A on ports #2 and #4.
All ports seems to work fine, suspend seems to work fine too.
Then I tried, in order:
  • removed the USB-A from port #4: no trace of the error message anymore.
  • connected the USB-A from port #2 into port #4 (port #2 left free): no error message
  • connected both USB-A on ports #2 and #4 but with modules swapped from the original configuration: no error message.
  • connected both USB-A on ports #2 and #4 as in original configuration: no error message…
So, I understand this issue is not easy to reproduce, as by swapping modules it disappeared and I currently cannot reproduce even with the same module configuration as when I had the error messages…
Arch Linux - kernel 6.12.4
I just hit this on an HX 370 mainboard after a forced poweroff from holding the fingerprint button down. I have USB-C on ports 1 and 3, USB-A on 2 and 4. The device plugged into my right side USB-A (port 4) wasn’t working (nothing on lsusb), and I noticed this message repeatedly spammed on dmesg:
xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
Moving the USB device to port 2 worked. Moving back to port 4 didn’t work. Removing the USB-A module in port 4 and reconnecting didn’t work. Removing and reconnecting the USB-A module in port 2 stopped the dmesg spam and my port 4 appears to be working normally now.
I get the message
kernel: xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
every few seconds on my Framework 13 AI 300 on Port 4.
If I have nothing in it, a SD card reader or a USB-A card.
It only stops as soon as I plug in a SD card or a USB drive.
That’s kind of annoying and I am unsure whether I should be worried.
Edit:
Reading the last post I removed the USB-A from slot 2 and put it to slot 4 and put the SD card reader to slot 2. And then the messages stopped.
I still don’t know whether I should be concerned or not.
I’m running into the same issue:
I’d rather this didn’t pollute my journalctl logs. I have an AI 300 too. I see this issue when I install a USB-A expansion cards in one of the front slots
I have the same issue with framework 13 AI 300 too
when i unplug the USB-A expansion card from port 2 (near left), the message stops spamming.
This is my current kernel version
6.16.4-2-MANJARO
Answers to your 5 questions :wink: :
  • 11th Gen Intel® Core™ i5-1135G7, Firmware: 03.22
  • Left side expansion slots are faulty or inconsistent in behavior. One USB-C to USB-A Card is inconsistent in behavior.
  • Upper left side USB-C is not working properly with FW-USB-C Card with my LG USB-C monitor. Very inconsistent, sometimes works, sometimes not. Also UBS-A 3.0 not working at all. Lower left side USB-C port is inconsistent. Worked today with Google Pixel USB-C to USB-A adapter.
    I for now use only the right side USB-C ports for USB-C and the lower left for some USB-A 3.0 connections. But 2day I had to switch also to right side port via a Anker USB-C hub to get my ext. DVD-drive working :frowning:
  • No
  • Don’t understand the questions TBH
  • Once, but didn’t follow up due to work and familiy business. Gets more annoying lately, so I digged a bit here in the forum to find out solutions.
    Had the issues with fedora (34 I guess, and also with my Debian Trixie/Forky / Sid setup. I even disabled USB-power management in TLP completely, still inconsistent.
P.S.: I was so far to upgrade my Mainboard to newer version. But as I read through the topic also latest Mains are affected? :open_mouth:
