Had the same issue that others have reported in this thread. My screen would consistently (read: every time) go white after I resumed from suspend. This was on a new Framework 13 AMD 7840 with Fedora 39 (6.7.11-200.fc39.x86_64), BIOS 03.03, and whatever UMA_GAME_OPTIMIZED defaults to.
When resuming from suspend, the display would flicker and I could see the desktop when moving my cursor but I could ctrl+alt+f3 to and the flickering and white screen would disappear. I could then restart gdm systemctl restart gdm to recover without restarting fully.
Ran the grubby sudo grubby --update-kernel=ALL --args=“amdgpu.sg_display=0” fix and it has immediately worked. I can now suspend and wake without any display issues. Hopefully this remains the case and it’s not just a coincidence.
I had the white screen flickering after a suspend lid closed (about 1 hour). I got through the white screen by moving the cursor as it would make the screen blink so I could see a bit of interface and go from there.
Looks like what Mattias has experienced.
I’ll run the grubby command now.
Cheers
Framework 13 AMD 7640u
UMA_GAME_OPTIMIZED is enabled in the BIOS. -> No
sudo grubby --update-kernel=ALL --args="amdgpu.sg_display=0" -> No
BIOS 3.03 Yes
Is this happening while gaming or watching videos/browsing? -> Long suspend lid closed.
Kernel version on Fedora Workstation 39 (6.6.12 or which?) -> Linux 6.8.4-200.fc39.x86_64 x86_64 Fedora Workstation 39
Same issue coming from lid closed (suspend) and also YouTube when made full screen. Ran the sudo grubby --update-kernel=ALL --args=“amdgpu.sg_display=0” several days ago and it is fixed now!
For other Linux distros that have this bug and are not Fedora-based, you can add amdgpu.sg_display=0 to kernel parameters (accessed by pressing e if using grub, see this Arch wiki page for other setups.)
