Things you can try
Way 1: Still use libinput (I didn’t go this route and need other people to try this to let me know if it works)
Way 2: Use synaptics
Way 1: Still using libinput
(note I haven’t personally tried this, but putting it out here just in case it works.)
The way you do it is to Edit the libinput .conf file
cd /usr/share/X11/xorg.conf.d
ls
You will see that there will be 40-libinput.conf (the number might not be 40 and that should be fine, Note if there’s another touchpad conf with a number lower than 40 it will override the libinput settings.)
You will add/update the ClickMethod and TappingButtonMap options in this section.
Section “InputClass”
Identifier “libinput touchpad catchall”
MatchIsTouchpad “on”
MatchDevicePath “/dev/input/event*”
Driver “libinput”
# clickfinger setting means that the number of fingers determines click rather than
# where you are clicking
# See this for more details: libinput: Clickpad software button behavior
Option “ClickMethod” “clickfinger” # YOU ADD THIS
# maps 1 finger tap to left, 2 fingers to right, 3 fingers to middle
# the setting is called tapping button map, so idk if it applies to clicks
Option “TappingButtonMap” “lrm” # YOU ADD THIS
EndSection
Way 2: Switch to Synaptics for touchpad input
Download synaptics command-not-found.com – synclient
check if you are running synaptics
a. Check the id of the Touchpad by running
xinput
Output looks something like this
Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Lenovo Optical USB Mouse id=9 [slave pointer (2)]
⎜ ↳ FRMW0001:00 32AC:0006 Consumer Control id=11 [slave pointer (2)]
⎜ ↳ PIXA3854:00 093A:0274 Mouse id=12 [slave pointer (2)]
⎜ ↳ PIXA3854:00 093A:0274 Touchpad id=13 [slave pointer (2)]
… # more stuff printed out
b. Check to see if the touchpad is running synaptics or libinput using
in this case the touch pad id number is 13.
xinput list-props {insert touchpad id number}
Output should look something like this
Device ‘PIXA3854:00 093A:0274 Touchpad’:
Device Enabled (178): 1
Coordinate Transformation Matrix (180): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
Device Accel Profile (309): 1
Device Accel Constant Deceleration (310): 2.500000
Device Accel Adaptive Deceleration (311): 1.000000
Device Accel Velocity Scaling (312): 12.500000
Synaptics Edges (332): 53, 1284, 47, 829
Synaptics Finger (333): 25, 30, 0
Synaptics Tap Time (334): 180
if you do not see synaptics running ^^,
ls
You will see that there will be 40-libinput.conf and 70-synaptics.conf
Here are a couple of things you can do.
a. I think that lower numbered settings override higher numbered settings, so you can rename 70-synaptics.conf to 30-synaptics.conf or something like that
b. Edit 40-libinput.conf (use sudo if they don’t let you edit)
MatchIsTouchpad “off” # THIS IS THE ONLY LINE CHANGED. TURN OFF
Driver “libinput”
EndSection
note the file has indents but idk why markdown isn’t capturing it
Make sure that you don’t have any typos in your .conf files or your computer won’t boot properly (mine got stuck on the framework logo from some other typo Ooops).
Test out synaptics settings
a. run synclient ClickFinger2=3 (it might be ClickFinger2=2 on some systems. I’m on kubuntu btw)
b. run synclient to see if the option got saved.
b. try out a 2 finger click.
Save your synaptics settings
a. cd /usr/share/X11/xorg.conf.d
b. edit xx-synaptics.conf (use sudo if they don’t want you to edit)
c. Add Option “ClickFinger2” “3” in the Section with identifier “touchpad catchall”
Here are my synaptics settings if you are curious
Identifier “touchpad catchall”
Driver “synaptics”
#This option is recommend on all Linux systems using evdev, but cannot be
#enabled by default. See the following link for details:
#Who-T: How to ignore configuration errors
Option “TapButton1” “1”
Option “TapButton2” “3”
Option “TapButton3” “2”
Option “ClickFinger1” “1”
Option “ClickFinger3” “2”
#synclient PalmDetect=1 IF YOU WANT PALM DETECT
Option “PalmDetect” “1”
#synclient PalmMinWidth=4
Option “PalmMinWidth” “4”
#synclient PalmMinZ=50
Option “PalmMinZ” “50”
Option “AreaRightEdge” “1050”
EndSection
Be careful about typos because your computer won’t boot if it can’t parse the data.
Booting issues after edits
If you do happen to make a typo and your computer cannot boot
- Boot in recovery mode
- select the root option
- Check the Xorg log files via vim Xorg.0.log (maybe also try Xorg.1.log) and find the error
It told me it could read 1050 because I forgot to put the quotes around it.
- Edit the file causing the error.
- reboot and it should work.
