Two finger scroll on touchpad is very jittery
When two finger scrolling the scroll is not smooth at all and tends to overshoot when you lift your fingers. Other laptops have a much smoother scroll. IS there a adjustment or fix for this?
Fedora Kinoite
Which release version?
43
2026/02/07
Which kernel are you using?
6.18.8
3.18
AMD Ryzen™ 7040 Series,
Other info.
Operating System: Fedora Linux 43
KDE Plasma Version: 6.5.5
KDE Frameworks Version: 6.22.0
Qt Version: 6.10.1
Kernel Version: 6.18.8-200.fc43.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 12 × AMD Ryzen 5 7640U w/ Radeon 760M Graphics
Memory: 32 GiB of RAM (30.6 GiB usable)
Graphics Processor: AMD Radeon 760M Graphics
Manufacturer: Framework
Product Name: Laptop 13 (AMD Ryzen 7040Series)
System Version: A5
Found a resolution.
I was adjusting the mouse pointer speed and scrolling speed. This had no impact.
I discovered there is a separate tab for touch-pad adjustments. Adjusted the scroll speed for the touch-pad and things have settled down nicely.
This comes down to a lack of experience with KDE on a laptop.
