Hello! I’ve got the new Framework 16 DIY edition. When setting up windows and I reach the “Let’s connect you to a network” page, no wifi shows up.
the first sentence of the tutorial. when i had that problem I opened the console when on that screen end typed the command to skip that step( press Shift+F10 to launch Command Prompt. Then, type OOBE\BYPASSNRO press Enter). and then used a usb drive to install the drivers.
