Could i upgrade my framework laptop 13 from an 11 gen i5 straight to the ryzen 5 7640u with the conversion kit?
Yes, just make sure you have the correct DDR5-5600 RAM, since the RAM you are using with 11th gen Intel will not be compatible with AMD.
Also wifi/bluetooth: your existing antenna will work, but you’ll want a Framework | AMD RZ616 Wi-Fi 6E
I upgraded from the 12th gen, it’s a big improvement.
