I have bought a usb c to multiport hdmi hub all the other ports work but the hdmi port when I plug it to upper two usb c port to that hub and connect the hdmi port the tv shows no signal I am on ubuntu 24.10 with fw13 amd 7840u
this is the hub i bought : USB C Hub with Ethernet Adapter, 8 In 1 USB C Multiport Adapter with 100W PD, 4K HDMI, USB 3.0/2.0, Type C Port, SD/TF Card Reader, USB C Adapter for iPhone 16/15, MacBook, iPad, Samsung, Surface, etc: Amazon.co.uk: Computers & Accessories
I’ve tried a bunch of those things. Some work, some have issues. This one works for me: https://www.amazon.nl/dp/B0BXDQS4BD?ref_=pe_28126711_487767311_302_E_DDE_dt_1
Some didn’t do 1440p. Some only worked on only 1 HDMI port. (I’m using 2).
Probably not that helpful but maybe if some more people chime in we might found out what’s going on.
EDIT: Found this: USB-C/Thunderbolt Dock Megathread
Thanks for the info
Update the issue is resolved and the hub works very well with the laptop
Can you explain how you fixed it so people having the same problem know how to fix it?
yeah sure the problem was not actually the hub, laptop or os because when I tried the same hub on different monitors and tv it worked as usual. The first tv I tried it on just before writing this post turns out to had hdmi problem in the tv itself because it wasn’t picking hdmi signal from any laptop.
