USB ports on and off
Hi,
Anyone have problem with the USB ports?
The device gets detected… disconnected… detected again… and so on.
Jean
You may take a look at this:
Does it do that with all USB devices or just one in particular?
@Jean_Gaudreau1 Does this only happen in the Lower left or upper right port?
If so we have a firmware fix coming to fix this.
Also what device are you using that is causing this?
The problem occurs with these devices so far :
DataTraveler 100 G3, 32GB
Nexiq USBLINK2 Bluetooth, this device connect with USB and Bluetooth
https://www.nexiq.com/Product/Detail/124032
