Usb ports stopped working framework 16 ai 300
hello so recently 4 of my usb ports just suddently stopped working and i can’t figure out why. i am getting errors abotu usb tho.
.-------------------------: c2@cachywork
:++===++==================- :+± OS: CachyOS x86_64
:*++====+++++=============- .==: Host: Laptop 16 (AMD Ryzen AI 300 Series) (A9)
-*+++=====+***++==========: Kernel: Linux 6.18.21-1-cachyos-lts
=*++++========------------: Uptime: 5 mins
=*+++++=====- … Packages: 1605 (pacman), 14 (flatpak)
.++++++=-===: .=+++=: Shell: bash 5.3.9
:++++=====-==: -+ Display (NE160QDM-NZ6): 2560x1600 @ 1.59x in 16", 165 Hz [Built-in]
+. WM: Hyprland 0.54.3 (Wayland)
.+==========-. . Cursor: Adwaita
:+++++++====- .–==-. Terminal: kitty 0.46.2
:++==========. :+++++++: Terminal Font: NotoSansMono-Regular (11pt)
**++ CPU: AMD Ryzen AI 9 HX 370 (24) @ 5.16 GHz
.-===========: .++: GPU 1: AMD Radeon 890M Graphics [Integrated]
-=======++++:::::::::::::::::::::::::-: .—: GPU 2: NVIDIA GeForce RTX 5070 Max-Q / Mobile [Discrete]
***********=. Memory: 7.96 GiB / 93.58 GiB (9%)
- Swap: 0 B / 109.58 GiB (0%)
.====++==============+++++++++± Disk (/): 1.35 TiB / 1.80 TiB (75%) - xfs
.===+==================+++++++: Disk (/home/c2/ssd2): 75.27 GiB / 1.82 TiB (4%) - xfs
.-=======================+++: Local IP (wlan0): 10.0.0.146/24
… Battery (FRANDBA): 99% [Charging, AC Connected]
Locale: en_US.UTF-8
[c2@cachywork ~]$
You probably tripped the overcurrent protection which is really easy to do (unfortunately).
  1. Go to BIOS
  2. Unplug the device from AC power
  3. Enabled the “disconnect from battery” feature
  4. Save and shutdown
  5. wait 5 seconds
  6. Plug device back into AC power
This reset’s the EC in charge of the usb. Alternatively you can shut down the device, unplug it from power, and wait 120 seconds (this is slower).
I’ve helped ~two dozen people with similar issues and this has resolved it for all of them.
yeah i already tried that and it didn’t work
also i do nto need help anymore as framework is sending me a replacement board
Glad they were able to resolve your issue :slight_smile:
Would you mind updating your thread title with a tag like [resolved]?
